Detonation in the b20. What to do??
Old Sep 7, 2002 | 11:19 AM
jcivicsib20's Avatar
Default Detonation in the b20. What to do??
I have a crvtec setup with 12.5-1 compression. I am getting pinging at midrange from my car and reducing the timing to 12 degress didnt do the trick. I am running b17 cams in a type r head. My vafc is is turned up positive all through the power band. Regulator is set at 50 psi. Do I need to upgrade injectors or are the stock valves getting too hot from the compression creating that pinging. Other than that the car runs hard and vtec kicks ***. Only pinging a narrow throttle, not full.
Old Sep 7, 2002 | 11:22 AM
C-speed's Avatar
Default Re: Detonation in the b20. What to do?? (jcivicsib20)
pull more timing.. The stock injectors are probably maxed out too.
eric1180
Feb 13, 2010 11:14 PM
fatalman
17
Oct 31, 2005 11:17 PM
jcivicsib20
Dec 26, 2002 12:55 PM
jcivicsib20
Sep 14, 2002 09:54 PM
