Accord shakes when accelerated
Old Feb 27, 2010 | 08:08 AM
sneaks's Avatar
Default Accord shakes when accelerated
Just bought a 94 Accord 80k. 5 spd. I just noticed that when I accelerate it seems to shake. But when I decelerate it stops. No CEL on. Tires are brand new. It only seems to shake when I give it gas.
Old Feb 27, 2010 | 08:09 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Accord shakes when accelerated
If it didn't do it before the new tires, I would say they weren't mounted and balanced correctly.
Also have your car fully aligned.
Old Feb 27, 2010 | 10:11 AM
cstone's Avatar
Check the motor mounts if that doesnt turn anything up. But I second TheMuffinMan's sugestions too.
Wouldnt that normally make it shake some when slowing down also though TheMuffinMan? Thats what made me think of mounts.
Old Feb 27, 2010 | 06:09 PM
tamadrummer1120's Avatar
no muffin man is right.
also bad inboard joints on the axles can have a slight vibration on acceleration.
Old Feb 28, 2010 | 07:17 AM
ken9's Avatar
Damn that very low mileage you got there..I got 300 000 kim on mine and it shake when i accelerate..
Old Feb 28, 2010 | 07:28 AM
94LS_allmota's Avatar
i dont own an accord but i had the same problem n it was my driver side cv axle....
Old Feb 28, 2010 | 07:45 AM
Yeah, it most likely would. If it's just braking it's generally warped rotors. It is possible that it's just not noticed while braking.
My point of mentioning if it didn't happen before the new tires it's probably either the mount/balance or even could be bad tires (the cords are messed up)
The motor mounts definitely are another possibility too - it's possible that the old tires were worn to a point the vibration wasn't noticed haha. Easiest way to check that is pop the hood and have a friend rev the motor up while you look. If there's a silly amount of flex in the mount then you'll want to replace.
Hope it's not the rear one though, that's a bitch to change.
Old Feb 28, 2010 | 08:17 PM
sneaks's Avatar
I was thinking motor mounts.
I pulled the spark plug wires and noticed one was drenched in oil. Could this be it? Making the enigine struggle when accelerating? IDK.
Old Feb 28, 2010 | 08:18 PM
fatboy1185's Avatar
Big Cat
Axle issue if it only vibrates on acceleration most likely.
sneaks's Avatar
I have no idea if it did it before the new tires. I just bought the car.
Old Feb 28, 2010 | 08:34 PM
oj5joker's Avatar
I had a Similar problem to as what you said, but mine was because my driver side lug nuts weren't properly torqued. It mad noise and was shakin but when I braked it went away. So check to see if they properly torqued the lug nut also
Old Feb 28, 2010 | 08:59 PM
ehudslefthand's Avatar
New User
Icon2 Re: Accord shakes when accelerated
I have the opposite vibration mine vibrates all the time ecept in drive, probably the rear motor mount with my luck. i did notice i was missing bolts in the front one and put some bolts back in it, but that didnt change it at all. oh well just how hard is the rear motor mount to replace?
Old Feb 28, 2010 | 09:04 PM
sneaks's Avatar
I heard the rear one is difficult. Im gunna looking into all this and see if I can come up with anything.
kenp35
Aug 1, 2018 12:56 AM
uberEFtuner
Dec 4, 2013 03:14 PM
lscrystal
Oct 15, 2012 10:13 AM
newtothescene
Feb 17, 2008 09:56 AM
