B16a HELP!!!
I got a B16 in my hatch.
and im having water in my oil.
I bought the motor with "low miles"
If there is water coming out my intake manifold.
does that mean the intake gasket is bad??
If water is getting into the oil, it's probably a head gasket if anything. Do a compression check if you have the equipment, and see if you have low compression on a cylinder. Also, if the car is going from hot to cold conditions frequently, or you don't drive it a lot, it could just be condensation build-up. Is your coolant system losing coolant?
Its a Brand new Skunk 2 Pro series manifold.
its coming out of the idle control, and second
SOUNDS LIKE A GREAT IDEA. the motor has been sitting for
3 months. does anyone know what the compression should
be at for each cylinder?
sr20paisa
Oct 9, 2015 08:17 PM
Bigblackhoe
14
Feb 18, 2011 10:55 PM
Mr.Chow
Jun 14, 2006 12:39 PM
