B16a HELP!!!
B16a HELP!!!
I got a B16 in my hatch.
and im having water in my oil.
I bought the motor with "low miles"
If there is water coming out my intake manifold.
does that mean the intake gasket is bad??
Re: B16a HELP!!!
If water is getting into the oil, it's probably a head gasket if anything. Do a compression check if you have the equipment, and see if you have low compression on a cylinder. Also, if the car is going from hot to cold conditions frequently, or you don't drive it a lot, it could just be condensation build-up. Is your coolant system losing coolant?
Re: B16a HELP!!!
Its a Brand new Skunk 2 Pro series manifold.
its coming out of the idle control, and second
SOUNDS LIKE A GREAT IDEA. the motor has been sitting for
3 months. does anyone know what the compression should
be at for each cylinder?
sr20paisa
10-09-2015 08:17 PM
Mr.Chow
06-14-2006 12:39 PM
