obd1 swap
Old Feb 25, 2010 | 01:47 PM
damn_import_culture's Avatar
Default obd1 swap
ok so if i get a motor trany ecu and motor harnes from a eg what else or do i need anything else to put this setup in my ed??? i seen some similiar post about obd1 andmp swaps but none answer my ? per say thanx
Old Feb 25, 2010 | 01:55 PM
BiG ChOr!Zo's Avatar
Default Re: obd1 swap
http://ef-honda.com/ben/EFswapguide.php
gibsanez's Avatar
To use the OBD1 ECU you will need an OBD0-OBD1 jumper harness. The ECU plugs are not the same.
Old Feb 25, 2010 | 01:59 PM
ok i thought thats all id need from ry wire but wanted to get a double check on it thanx
so would i need this one
http://rywire.com/store/obd0-obd1-co...61d144a0b9cecb
or this one??
im guessing i need the first but the second opininion is usefull
Old Feb 25, 2010 | 02:41 PM
jlicrx's Avatar
to run the EG transmission in the ED, you would also need a hydraulic to cable clutch conversion and mount kit:
http://hasport.com/store/index.php/efdhc.html
Old Feb 25, 2010 | 03:18 PM
gibsanez's Avatar
The second link says "THIS IS ONLY FOR OVERSEAS UKDM, JDM CRX SiR vehicles."
Do you have a JDM or UKDM SiR?
Old Feb 25, 2010 | 03:55 PM
no i noticedc that after post so harness one it is
Old Feb 25, 2010 | 04:34 PM
Creator's Avatar
I believe you'll need a 4 wire O2 sensor, and a OBD1 distributor as well.
90crxef
Apr 6, 2008 06:02 PM
civicxxman
11
Mar 2, 2008 05:40 AM
downsycrx
Sep 25, 2006 10:52 AM
JDM B16A
11
Jun 20, 2006 09:50 AM
mrx
Feb 25, 2005 12:36 AM
