adjusting camber?
Old Sep 7, 2002 | 06:24 AM
mr tl's Avatar
Default adjusting camber?
the only way to adjust camber is with a camber kit, or replacing the factory ball joints (to get to factory specs). is this correct?
does normal wear and tear cause camber to go out of spec?
thanks
Old Sep 7, 2002 | 08:36 AM
Aron Parsons's Avatar
Default Re: adjusting camber? (mr tl)
camber doesn't change much over time. the main factor in camber are your springs. shorter springs=lower ride height=more negative camber, good for the corners. if you want to adjust your camber, the kits are the only way to go. however, i've read in the past month in a few posts here that the camber kits are mainly intended for street use, not quite for racing.
Old Sep 7, 2002 | 09:39 AM
mr tl's Avatar
thanks man
TegGsr4dr
Jul 10, 2007 09:35 AM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
mattdenali
Suspension & Brakes
May 26, 2005 09:21 PM
jdmkrazie
Nov 4, 2004 03:38 AM
AcCO12D95
Jun 12, 2004 10:48 AM
