new member with a swap question
Old Feb 24, 2010 | 06:11 PM
glorious87's Avatar
Default new member with a swap question
the car, 89 wagovan, manual
the swap, y7 motor and intake mani, b16 TB, obd0 SI dizzy and injectors.
i will be customizing the stock dpfi air chamber box that sits on top of the stock TB to fit on the b16 TB. the idea is to keep it looking as stock as possible. here are my questions...
the tb im using
the intake im using
the air chamber
now, where would i put an idle air control valve? i relocated the intake air intake temp sensor to the air chamber before the TB.i have to have the stock throttle cable modified. but would it be eisier to convert to obd2? because i would REALLY like to keep it obd0 and im sure theres a way. also, what happens to the A/C idle compensator. i want to keep ac and i need a way to raise the idle when i turn it on. i know EG civics use a newer style then the EFs. so could i figure a way to use a newer style?
thank you in advance.
david
Old Feb 24, 2010 | 06:13 PM
crx_si-r's Avatar
Default Re: new member with a swap question
you might as well get the TB from the y7 set up. or custom make a new manifold with a cross from the DPFi and the Y7.
Old Feb 24, 2010 | 06:14 PM
glorious87's Avatar
y7 is mpfi.....
Old Feb 24, 2010 | 06:17 PM
crx_si-r's Avatar
Originally Posted by glorious87
y7 is mpfi.....
yea my bad. i saw a dpfi top and thought it was a dpfi manifold.
crx_si-r's Avatar
also why not run a Y8 manifold?
Old Feb 24, 2010 | 06:22 PM
glorious87's Avatar
because i want it to resemble the stock dpfi d15 setup. its just how i want to do it, theres a method to my madness.
Old Feb 24, 2010 | 06:37 PM
D16SiHatch's Avatar
you want it to be slow... ? lol
Old Feb 24, 2010 | 06:49 PM
glorious87's Avatar
if you dont know the answer the the question just move on.
Old Feb 24, 2010 | 06:57 PM
D16SiHatch's Avatar
its a legitimate question. you're trying to do somethin that doesn't really make a whole lot of sense, so i feel it's reasonable to inquire why.
Old Feb 24, 2010 | 07:03 PM
projekt90ef's Avatar
sober up then repost homie
Old Feb 24, 2010 | 07:15 PM
glorious87's Avatar
i have multiple hondas, i have done countless swaps and this car is not oriented twords speed. its just something i want to build for fun. i dont care if its the slowest thing in the world. i dont want a y8 because everyone has a y8. i want this motor, i want this intake, and i dont care to know what you all think about it. i just need answers from someone who knows how to do more then simple bolt together swaps. if i cant run obd0 withough an ef IACV then i will cut and weld a spot on the back of the intake to run it. this car has a theme to it, its not a racecar.
Old Feb 24, 2010 | 07:36 PM
is it a tribute to ur grandmas shopping commuter?
Old Feb 24, 2010 | 07:43 PM
D16SiHatch's Avatar
he wasn't being a dick, no need for you to be.
Old Feb 25, 2010 | 08:15 AM
glorious87's Avatar
bump
Old Feb 25, 2010 | 09:34 AM
hatchet_honda's Avatar
cool idea i guess..somethin different..but anyone you show it to will just be like wtf? whyy?
Old Feb 25, 2010 | 01:01 PM
glorious87's Avatar
actually it was my friends idea, lol. i was planning on doing a full dual point turbo setup. but i assume this would make more power for less money.
Old Feb 25, 2010 | 06:38 PM
glorious87's Avatar
no one?
Ohmega
Oct 20, 2015 03:09 PM
josh352727
Dec 22, 2008 07:30 PM
locomotived
Honda Civic (2006 - 2015)
Jul 3, 2007 09:43 PM
b-power
Oct 31, 2004 07:35 PM
Milano95
Aug 19, 2001 05:00 AM
