obd0 b16 head
Old Feb 24, 2010 | 11:31 AM
cedric dc4's Avatar
Default obd0 b16 head
i have a question. i recently got a obd0 b16 head for my ls block my car is a obd2 would this be a problem to do ls vtec since my car is a obd2 and the head is obd0? i been getting different answers
Old Feb 24, 2010 | 11:41 AM
DumaDA's Avatar
Default Re: obd0 b16 head
i think there shouldnt be a problem as long as you use the obd2 ls intake manifold and obd2 dizzy
Old Feb 24, 2010 | 11:55 AM
cedric dc4's Avatar
Ok so I can use my Ls intake manifold and my Ls dizzy or find a different dizzy and what timing belt do I get?
Old Feb 24, 2010 | 12:02 PM
cedric dc4's Avatar
Old Feb 24, 2010 | 01:10 PM
DumaDA's Avatar
you can use your ls dizzy but you'll need to modify it, or you can just buy a obd2 gsr or civic si dizzy. The manifold will work. If you're building an lsvtec motor i would suggest gsr water pump and timing belt along with oil pump
Old Feb 24, 2010 | 04:27 PM
cedric dc4's Avatar
ok cool thanks for your help
Old Mar 2, 2010 | 04:29 PM
cedric dc4's Avatar
can i use stock head bolts or do i have to upgrade on that and head gasket?
Old Mar 2, 2010 | 05:43 PM
ef9er0's Avatar
here u go
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Mar 2, 2010 | 05:44 PM
ef9er0's Avatar
DO NOT USE UR STOCK HEAD STUDS!!! DONT CHEAP OUT ON PARTS IF U WANT UR MOTOR TO LAST, AND WANT TO DO IT RIGHT!!!!!!
Wilka
Apr 20, 2012 10:46 AM
Fezzie
Dec 13, 2006 03:40 PM
e she i
Nov 19, 2006 04:09 PM
GDM93Si
Nov 12, 2004 10:47 PM
civicrtype
Jul 30, 2003 11:11 PM
