Steering wheel shaking a lot when braking at high speeds
Old Feb 24, 2010 | 10:37 AM
kevcha711's Avatar
Default Steering wheel shaking a lot when braking at high speeds
Just like the title says. A lot of shaking when braking. The shaking isn't as bad when downshifting and braking but there's still something wrong. Any help would be great
Old Feb 24, 2010 | 11:04 AM
BrayzieEF9's Avatar
Default Re: Steering wheel shaking a lot when braking at high speeds
is there only shaking when braking or while driving too??
Old Feb 24, 2010 | 11:05 AM
4g4dcruisin's Avatar
While down shifting...
-Wheel bearing could be out, causing uneven decelleration
-Alignment could be off.
While braking...
-Rotors are warped
-Brake pads are worn down unevenly.
Old Feb 24, 2010 | 11:36 AM
USNneverAGAIN07's Avatar
While braking...
-Rotors are warped
and your tie rods could be shot. it could be a number of things
Old Feb 24, 2010 | 12:36 PM
jayturboef's Avatar
most likely ur rotors.... change them and it should stop
Old Feb 24, 2010 | 12:53 PM
MrFunCRX's Avatar
i had this same problem it was my tie rod it ended up snapping and i went for a 360 degree ride doing 65 on the interstate.
Old Feb 24, 2010 | 02:08 PM
88CiViCtechy's Avatar
Start with your rotors, they are likely warped.
Old Feb 24, 2010 | 02:38 PM
kevcha711's Avatar
Thanks for the help everyone
Old Feb 24, 2010 | 02:39 PM
Tyson's Avatar
the obvious answer is your rotors are in need of replacement.
however, the REAL problem is a lot of play in your steering and suspension is amplifying the "warpage" in your rotors. to fix the PROBLEM, you need to fix the steering first.
most likely your rack end bushing is shot. not only that, but your tie rod and balljoints could be in need to replacement too.
once you fix your steering, you should replace your rotors. replacing only your rotors now will cause your new rotors to "warp" very quickly.
the steering wheel should not shake, even with "warped" rotors. the shake and looseness and clunking in your steering needs to be addressed.
Old Jun 2, 2010 | 09:45 PM
Rob.'s Avatar
^^ yup.. very good info here ! Rotors "warp" because of either loose/shot suspension components or over heating the rotors at teh track, (or cheap made in China rotors) LoL
AViciousTHRUST
Apr 2, 2006 08:30 AM
JDM_SOHC
12
Dec 1, 2005 09:33 AM
zseeanz
Mar 24, 2004 02:41 PM
tornactive.com
May 3, 2002 06:17 PM
MaD3 In JaPaN
Mar 3, 2002 05:41 PM
