someone help me! '90 crx si troubles
i have a gsr swap in my crx and the car "bogs"/"sputters" when i punch on the gas.
the idle on the car is very very low sometimes at 400rpm or 500rpm
and then it moves to 1000rpm at times.
the check engine light throws code 4 code 9 and code 43.
can anyone help me or give me advice on what to do or what those codes mean???
code 4 is you crankshaft position sensor - need new distributor
code 9 is cylinder position sensor - need new distributor
code 43 is fuel supply system - usual fix is new 02 sensor
Airbag Club
11
Mar 10, 2005 03:05 PM
