Help identifying this JRSC part
looks to be the adapter that bolts in between ur fuel pressure regulator and fuel rail. u may need it due to clearance issues on the fuel return line. it rotates your fpr so the return line doesnt hit ur intake plenum.
Thanks.
He is 100 % correct and if you have it I dont see why you wouldnt use it .I did not have that part when I got my jrsc at first and had to bend the return line on my regulator it worked but it sure was a close fit to my intake with the return line .
If you click this link and look at the pic of my set up you can see how tight of a fit it was without the fpr adapter .I also have the LHT set up which probably didnt help . I have since installed the adapter .
https://honda-tech.com/forums/showth...14810&page=504
