***The Official JRSC Thread***
re: ***The Official JRSC Thread
Type r head p&p full valve train
LS block with some good tricks done
12.5:1 Compression
Light crank and rods
7.5 pound flywheel
19psi
nx direct port 150 shot
12.5:1 Compression
7.5 pound flywheel
19psi
oh alright your engine bay looks exactly like a kid around here
any shots of the front heat exchanger? I've never seen one installed
hey guys. just an update. got a decent dyno tune and car is running good.
my final numbers were 153hp, 119tq on a mustang dyno. motor is a LS w/ upgrade kit.
interesting thing - i was getting good gains especially in the higher range, tuner says the boost wants to go even higher than 11psi so that boost upgrade kit from JR is capable of more. its a shame that heat is an issue and LS are only capable of about max ~7000rpm.
so some more issues to work out are:
1) new intake - cold air or air box (pulling the SRI out of the bay and pointing upwards into fresh air made a huge diff during dyno.)
2) better exhaust, it still sounds all raspy and ricey
3) something to vent the heat - hood tilt or vented hood
4) some sort of meth injection or lht (dont have the funds yet)
Ok guys think I am selling everything,lol. Even the car you think this is a ok price..
I have for sale a super complete Jackson racing supercharger kit for a gsr. The only thing you should need to put this in is some hondabond to seal it up. Comes with everything seen in picture and s pipe for got it was sitting on different shelf. I can also include 510cc injectors(flow tested, clips included) for an additional 100 bucks with the kit.
Looking to get 1100 shipped which is a good deal
1 Post
WOW, looking very slick! Those 2 clear tubes are routing to the heat exchanger? Also what is this reservoir that's needed, but not included in the kit? What did you use? What header are you running?
Thanks for posting the pictures
Well the hoses are for the heat exchanger and a reservoir is not required the lht system currently holds almost a gallon of liquid but I have considered installing one. If you look at my passenger side strut tower you can see the brass fitting I have for filling the lht. It works out pretty well I may modify that down the road also for easy drainage so I can put antifreeze in it in the winter. For now (summertime)I used distilled water and water wetter my top intake temps on the dyno were 105 . The header if from LHT also .
I have a question for everyone about the map sensor. I know that for the map to see boost, you have to nipple it to the manifold. Im planning on getting a 3bar, so is there any reason to purchase the hondata map bypass?
q? why would there be oil in my intake...? (its a small amount)
its coming from the tube that connects from the intake to the engine.. (breather hole)
98 civic hatch cx
2001 b18c5
jrsc 6psi
walbro fuel pump
rc injectors 440 cc
aem FPR
MSD blaster coil setup
ACT stage 2 clutch
ACT 7.5 lb flywheel
AEM cold air
Skunk 2 stage 2 cams
springs retainers
no pwr steering
275whp
2001 b18c5
jrsc 6psi
walbro fuel pump
rc injectors 440 cc
aem FPR
ACT stage 2 clutch
ACT 7.5 lb flywheel
AEM cold air
springs retainers
no pwr steering
275whp
Lets see that dyno print out I'm at 260 in a 97 hatch and its nuckin futs a total blast to drive wheel spin was an issue until I learned to launch it .You kinda have to modulate the pedal a bit in first and second if you mash it it'll wheel hop the quaife lsd has helped but I still had to learn to drive it
The tube is the line from your Positive Crankcase Ventilation (PCV) system; it's supposed to recirculate oily crankcase gases through your intake, which looks like exactly what it's doing.
That is one of the main reasons people run a catch can setup, or some other setup that will keep that oil out of the intake / blower.
is it possible for the nose pulley to be wobbling? maybe it needs changing?
anybody had this problem? i think its whats making a funny noise also.
anyone have one for sale?
