key stuck in ignition
Old Feb 23, 2010 | 05:57 PM
tuscaloosahonda's Avatar
New User
Default key stuck in ignition
Help! I have a 2006 Honda Oddysey, and the key will not return to the lock position so that I can remove it from the ignition. The van is in Park, wheels are straight, everything is turned off, etc.
I understand that under the steering wheel there might be a cable that has gone bad?
Is there a good way to get this key out manually without paying someone a boatload of cash?
Scott Bullard
Tuscaloosa
Old Feb 23, 2010 | 06:52 PM
jonnyt1130's Avatar
Default Re: key stuck in ignition
you can try putting it in nuetral too.
Old Feb 23, 2010 | 07:43 PM
honda_S's Avatar
Are u still able to push the key inward?
Old Feb 24, 2010 | 10:55 PM
seanbev24's Avatar
I worked on a car the other day that wouldn't start, which turned out to be a bad ignition switch. When I unplugged the switch, I couldn't remove the key. Maybe your switch has gone bad or there is a bad connection?
Barf Hat
Oct 9, 2019 05:45 AM
piercedpanda
Honda Fit
Sep 21, 2017 11:07 AM
phillbo
Jan 20, 2007 09:48 AM
GregT
Acura TL, RL & ZDX
Dec 24, 2006 07:13 PM
vaporboy12
Aug 29, 2005 07:22 PM
