keeping a/c with a b swap?
Old Feb 23, 2010 | 04:02 PM
black0hatch's Avatar
Default keeping a/c with a b swap?
first of all whats the going price to recarge an a/c system? i heard the older cars are expensive. and how do you keep a/c with a b swap?
Old Feb 23, 2010 | 04:23 PM
EFRue57's Avatar
Default Re: keeping a/c with a b swap?
you just need this bracket from hasport
http://hasport.com/store/index.php/a...s/ac/efac.html
and to answer your question about how much to charge, just go to a place that does a/c recharging and ask them.
Old Feb 23, 2010 | 06:09 PM
zrickety's Avatar
convert to r134a and it's much cheaper...kit and refrigerant is less than $60.
i would recommend using a newer b-series compressor made for r134a.
then you can use that bracket, and just have a hydraulics shop modify the hoses to fit your car
Old Feb 23, 2010 | 06:41 PM
88CiViCtechy's Avatar
i know i was able to keep it in the $100 price range...
Old Feb 23, 2010 | 07:06 PM
EFRue57's Avatar
unless i'm mistaken, with that bracket you do not use the b series compressor but the d series compressor. also you use the factory a/c line, definitely not custom ones, because a friend of mine had his cr-x with a b series swap, used the hasport bracket, and used the stock a/c lines.
Old Feb 23, 2010 | 07:12 PM
Deetz's Avatar
Crazy Honda Guy
A couple of good options for the A/C compressor bracket...
- oem crv B20 bracket
- innovative
Old Feb 23, 2010 | 07:16 PM
EFRue57's Avatar
i could be wrong Deetz, but I thought the CRV bracket only worked in eg and ek chassis, not the ef, which is why companies like hasport and innovative make the adapter bracket for the ef and it is not compatible with the eg/ek chassis.
Old Feb 23, 2010 | 07:19 PM
Deetz's Avatar
Crazy Honda Guy
The crv bracket fits d series compressors. It does have a leg that sticks out a bit, but that can be just cut off and used in an EF chassis, after all, it just needs to bolt to the block
Old Feb 23, 2010 | 07:23 PM
EFRue57's Avatar
okay, good to know, i've never used the crv bracket on an ef chassis so was unsure. thanks for the info.
Old Feb 24, 2010 | 05:31 PM
has anyone actually used the b20 bracket? if you can why would people spend so much on an aftermarket one?
Old Feb 24, 2010 | 05:55 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I used the PR3 bracket that comes with the swap
and modified it to fit my SANDEN brand compressor..
The front two compressor bolts line up but the rear two don't
so you have to fab up at the very least a third bolt..
NOTE: It won't work with the MATSUSHITA brand
and I used the Hasport engine mounts..
{ Other brands may yield different results..}
I also had to make a big dent in the front crossmember for the
compressor to clear..
As far as refrigerant,You can find R-12 on Craig's list all day long..
Old Feb 25, 2010 | 07:38 AM
HAMOTORSPORTS's Avatar
The Del sol / CRV brackets work with D Series AC compressors on B series block into Eg and EK. The EF D series compressor is a little different and needs either the Hasport EFAC bracket, or the Innovative EF AC Bracket. These brackets supposedly only work with SANDEN brand AC compressors for the EF as far as I have heard. I have not physically tried any others.
** EDIT: The Hasport AC bracket for the EF works with both Sanden AND Matsushita Compressors **
Old Feb 25, 2010 | 10:37 AM
EJ1_Sleeper's Avatar
yup you use the aftermarket bracket and oem compressor with oem lines. i was almost ready to get mine all bolted up...and then the day i was pulling the parts i needed my tools were stolen from the junkyard out in the yard. so now im just waiting till i get more tools to do anything. (lost the parts i pulled too..)
Old Feb 25, 2010 | 08:24 PM
keithg's Avatar
FWIW the Hasport A/C bracket (EFAC) will work with either the Sanden or Matushita compressor, it has provisions for both.
Old Feb 25, 2010 | 08:29 PM
Deetz's Avatar
Crazy Honda Guy
Really??? I ordered one for my crx about 5 years ago.....didn't fit, i returned it
I wonder if it is a different design now?
Old Feb 26, 2010 | 05:29 PM
keithg's Avatar
I don't know what to say... IIRC it's been that way since day one, but I could be wrong.
Check out the picture in the link you can see the dual bolt pattern for the compressors.
It's only the lower left bolt hole that is different between the two compressors and the stand-off for that one bolt is different too.
http://hasport.com/store/index.php/efac.html
Old Feb 26, 2010 | 09:23 PM
Ldo's Avatar
Ldo
That's true. Hasport's bracket works with both Matsu & Sanden compressors. Innovative's only works with Sanden. To be honest, with a B motor in the EF, we need as much room up front as we can, so the Sanden compressor seems to be the better choice.
Old Feb 26, 2010 | 09:41 PM
DCRB's Avatar
damn man this is faq status info imo.
Old Feb 26, 2010 | 11:09 PM
Clipsed's Avatar
agreed.
Old Feb 27, 2010 | 01:47 AM
WOW, nice call!
Learned something new! I see where that fourth bolt has two optional locations . . . time to go update the site, I've been telling people with the Matsushita compressor that they can only run AC if they switch to a Sanden AC compressor..
** Needs to be added to FAQ / stickied **
Old Feb 27, 2010 | 07:10 AM
keithg's Avatar
WOW, nice call!
I will make sure the info is added to our website as well, sorry we missed posting earlier.
Old Feb 27, 2010 | 07:12 AM
suwhoop's Avatar
who needs ac
Old Feb 27, 2010 | 02:16 PM
zrickety's Avatar
i was saying to use the newer b-series compressor with b-series bracket, with custom hoses.
i believe it works better (colder) than a converted sanden. but whatever works!
Old Feb 27, 2010 | 03:14 PM
Thanks Keith !
MShonda
Nov 22, 2010 07:20 PM
1zach4
Jul 25, 2010 03:53 PM
WhatThe EF
Jun 3, 2008 06:12 PM
BlackEG6
11
Aug 3, 2007 05:30 PM
HT Chaplain
Apr 12, 2003 09:18 AM
