removing p/s???...
Old Feb 23, 2010 | 01:14 PM
prox25's Avatar
Default removing p/s???...
i wanna remove my p/s but im a newB 2 it all dont really kno wut i gotta remove w/o realy fukin nuthn up!...i just wanna clean up my engine bay up sum more....also for my a/c its all gont e but ders still sum hoses!...does anybody kno a good DIY that shows all this?...thx
Old Feb 23, 2010 | 01:30 PM
heeltoehonda's Avatar
Default Re: removing p/s???...
Replace the power steering rack with a manual one to remove the pump, and the rest of what you said I can't answer because I couldn't understand you
Old Feb 23, 2010 | 01:42 PM
prox25's Avatar
oo okay so frm wut honda or wer can i get dat?...thnx man srry dont understand it myself....but i ment de a/c compressor is gone but ders still hoses all ovr tht seem 2 be frm a/c but not 100 sure on wuts safe 2 jus remove understand?
Old Feb 23, 2010 | 01:46 PM
You can get the manual rack at your local autoparts store for around $200. It's not a simple job though. If your not familar with it, get a haynes or chilton's maual to walk you through the steps. As for the A/C, you should be able to remove all the lines, someone correct me if I'm wrong though.
Old Feb 23, 2010 | 02:01 PM
prox25's Avatar
oo thnx man
Old Feb 23, 2010 | 06:55 PM
98civdx's Avatar
Master Detailer
you dont need to swap racks! power racks are better then non, with or with out power steering hooked up.
all you need to do is loop the lines, possibly put a breather in. theres a diy on here how to do it.
for the ac hoses just follow them to where they go, and un bolt them
Old Feb 24, 2010 | 04:12 AM
Matt93eg's Avatar
X2! No need to swap out the power rack with a manual rack for a P/S Delete. I have been running no P/S on my P/S rack for probably 4 years now, I have the lines looped with -AN fittings and Stainless steel braided hose so the rack is full of fluid.
Car is more enjoyable to drive IMO, you get more feedback from the road and the steering is not as twitchy. Some people complain about driving a Civic with no P/S in a parking lot trying to get into a tight space, but its not a problem and not hard. I'm not a big dude at all and I have no problems pulling in or backing out of tight parking spots, takes you a bit more time to turn the wheel but its not hard. My cousin has drivin my car to and shes pretty small and she didn't whine either. She did whine about my stage 2 clutch though
You could also just remove your P/S belt for a bit and drive around just to get a feel for what it will be like without P/S.
OP, BTW where are you from? I hope your not from the USA because your English skills suck, or are you just trying to type like some gangster?
Old Feb 24, 2010 | 05:18 AM
True, but IMO it is the best route. And the most expensive...
Do you think you could post up the link for the DIY thread? I've been wanting to get my hands on that for my buddy. That's what he's wanting to do. Thanks in advance
My buddy did that and his reservor that holds the P/S fluid over flowed like crazy. Is that a normal thing? Is it bad? Does it cause any damage? Thanks
Old Feb 24, 2010 | 07:21 AM
Matt93eg's Avatar
I drove around for a while with my P/S belt off back before I took it out to see how I liked it and I never had a problem with the reservoir overflowing or anything else. That's not to say other people haven't had problems when running without a P/S belt, just I didn't in my particular case.
Old Feb 24, 2010 | 07:33 AM
tokugawa's Avatar
New User
It's not very hard to remove,I took powersteering out of my eg and looped the hoses together. I never heard of using a breather it seems like it would leak.
Old Feb 24, 2010 | 07:37 AM
Matt93eg's Avatar
Yeah I don't know the specifics on the breather idea either, I know I have had my lines looped and I don't have any problems.
Old Feb 24, 2010 | 07:53 PM
He must have had to much fluid, who knows?
So it's as simple as removing the pump and and looping the lines while making sure fluid is still in them? Nothing else needs to be done?
Also can it be done with the engine still in the car?
Old Feb 25, 2010 | 05:48 AM
Matt93eg's Avatar
When I removed my P/S. I got rid of the Pump, reservoir, and all the rubber and hard lines. There was nothing left but the P/S Rack. You have a two holes on the rack where I assume fluid came out of one, traveled to the pump and return to the rack at the other hole. I used -AN fittings and S.S hose and looped those two holes together.
Actually now that I think even harder about it, there are 3 holes on the rack. The two I just mentioned and a third hole, Maybe this 3rd hole is where people put a breather, I was just instructed to use an automatic tranny flex plate bolt so that's what I did and haven't had any problems. I guess a breather there would help vent any pressure buildup from inside the rack but I would think it would leak? I haven't had any problems with that 3rd hole plugged with a bolt though.
And yes, it can all be removed with the engine in the car. I pulled the front bumper cover off to access the hard line that runs up by the core support, its got a bracket and bolts to the support.
Old Feb 25, 2010 | 05:57 AM
Ok, thanks for all the info
Old Feb 25, 2010 | 09:56 AM
98civdx's Avatar
Master Detailer
yes all you truely need to do is loop lines. keeping fulid in the rack is the key. the brather thing just keeps air out and it from runing dry.
there are 3 holes, all we have ever done is stick a bolt in the 3rd and loop the 2 lines that go from the pump to rack.
switching the rack is a bitch with the engine in, also heeltoehonda power racks are better then non, so no switch the rack would not be the best way.
ill look for the diy, and post it up when i find it.
Old Feb 25, 2010 | 10:02 AM
98civdx's Avatar
Master Detailer
dont think the pics work but the info is there also i think it explains the idea of a breather a bit better.
https://honda-tech.com/forums/acura-integra-type-r-8/how-power-steering-manual-184202/
Old Feb 25, 2010 | 10:10 AM
Just out of curiosity, why is the power rack better than the manual rack?
https://honda-tech.com/forums/showthread.php?t=184202
Thanks I really appriciate it
Old Feb 25, 2010 | 10:12 AM
98civdx's Avatar
Master Detailer
the power rack has quicker turning ratios, plus every car i have driven with manual rack **** shakes like crazy around 80mph.
Ohh ok, I gotcha. Thanks again
EG-SIXV-TEC
Jan 16, 2010 07:36 PM
Corksil
Aug 13, 2009 08:20 PM
bboixtc
Mar 21, 2009 10:22 PM
deadline
Suspension & Brakes
Nov 4, 2006 05:45 PM
96integraLS
Oct 13, 2004 02:07 PM
