Stereo Wiring, 92 Civic Si
OK, so my stock stereo harness is cut and an adapter has been spliced in with a constant power wire running straight to the battery.
I went to a junkyard and got a stock stereo connector and spliced it back onto the old harness. Of course, nothing works because everything has been bypassed. My question is, what do I need to connect to what to get it to work?
The speaker wires and everything have been rigged up. The CD player wont even turn on when plugged into the spliced-up stock connector. I really need to have music in my car.
Thanks Honda-Tech!
Thanks Honda-Tech!
Re: Stereo Wiring, 92 Civic Si
Good call.
So I took some pictures. Don't mind the shitty splicing of the connector, it's winter here and sitting in a freezing cold car splicing wires is no fun.
On the left is the connector (the stock one) and on the right is the adapter that was put in there. You can see the speaker wires all connected to it and ****.
have u tried tracing the wires back with a wiring diagram showing u were they should end up if not thats were i would start i got a honda factory service book for next to nothing off ebay and its help me a bunch with botch wire jobs on some of my friends cars
those it have power if not check the fuse i think it have 2 fuse one under the dash i think that 1 is power and the 1 under the hood is the back up i believe which is called backup for the memory .
