Vtec
what do u mean if i have it turned off? im running a p13-900 that has been converted to a manual ecu instead of auto.......i just wanna know if the vtec will work because my knock sensor broke? idk what u mean by having it turned off?
If you have an H22 and a P13 ECU then you will require the knock sensor. If your using a chipped OBD1 ECU with an H22 you can disable the knock sensor with tuning software.
I'm all for helping noobies out and all.... but seriously dude use the "search" function as it will give you all the answers you need..... hell I will do one for you and see what comes up....
wow here's one that relates....
https://honda-tech.com/forums/showth...sensor+problem
and another thing, try getting a knock sensor for an Oddysey from a Honda dealer - they're only about $35. (not bank breaking amount!!)
the oddysey sensor will work with my obd1 ecu? sorry prolly dumb question but just sounds wierd to me.....i thought knock sensors where obd1 or obd2 and you have to get the correct one.....if it will work out of a oddysey and its that cheap then i guess that solves my issue
Seriously dude... you can find all the information you need by using the search function....
https://honda-tech.com/forums/showth...y+knock+sensor
1SickHb
Nov 19, 2004 04:39 PM
