Vtec
Old Feb 23, 2010 | 09:50 AM
more3688's Avatar
Default Vtec
sense noone wants to respond to my other post im creating a new one.......WIL VTEC WORK WITHOUT A KNOCK SENSOR?
Old Feb 23, 2010 | 09:54 AM
ilikehonda's Avatar
Default Re: Vtec
yes if u have it turned off. if not ull throw a code and may go into safe mode
Old Feb 23, 2010 | 03:56 PM
more3688's Avatar
Default Re: Vtec
what do u mean if i have it turned off? im running a p13-900 that has been converted to a manual ecu instead of auto.......i just wanna know if the vtec will work because my knock sensor broke? idk what u mean by having it turned off?
Old Feb 23, 2010 | 04:59 PM
GhostAccord's Avatar
Default Re: Vtec
What engine and ECU are you using?
If you have an H22 and a P13 ECU then you will require the knock sensor. If your using a chipped OBD1 ECU with an H22 you can disable the knock sensor with tuning software.
Old Feb 23, 2010 | 05:00 PM
GlassJAw's Avatar
Default Re: Vtec
I'm all for helping noobies out and all.... but seriously dude use the "search" function as it will give you all the answers you need..... hell I will do one for you and see what comes up....
wow here's one that relates....
https://honda-tech.com/forums/showth...sensor+problem
and another thing, try getting a knock sensor for an Oddysey from a Honda dealer - they're only about $35. (not bank breaking amount!!)
Old Feb 23, 2010 | 09:58 PM
more3688's Avatar
Default Re: Vtec
the oddysey sensor will work with my obd1 ecu? sorry prolly dumb question but just sounds wierd to me.....i thought knock sensors where obd1 or obd2 and you have to get the correct one.....if it will work out of a oddysey and its that cheap then i guess that solves my issue
Old Feb 23, 2010 | 11:09 PM
GlassJAw's Avatar
Default Re: Vtec
Seriously dude... you can find all the information you need by using the search function....
https://honda-tech.com/forums/showth...y+knock+sensor
jdm_cd5
Nov 3, 2007 10:48 PM
LaosIntegra
Apr 18, 2005 09:33 PM
1SickHb
Nov 19, 2004 04:39 PM
stubk20
Jul 6, 2004 11:59 PM
codeh22a4
Apr 8, 2004 12:51 AM
