sohc vtec ecu??
Old Feb 22, 2010 | 02:14 PM
striker5661's Avatar
Icon6 sohc vtec ecu??
can anyone tell me what ecu i need for a d16z6 i have a 96 dx which has the d16y7 and im getting a z6 vtec head for i i need the ecu for it but im not sure which one i need any info would be helpful thanks
Old Feb 22, 2010 | 02:35 PM
accord2civic2prelude's Avatar
Default Re: sohc vtec ecu??
yours is obd2. so get a p28 with a obd1-obd2 jumper harness.
Old Feb 22, 2010 | 02:41 PM
FRESHTEG's Avatar
^^yeah and did u buy a new harness or are u wiring up vtec urself
Old Feb 22, 2010 | 02:49 PM
wire vtec yourself..its not that hard either. better than getting a whole new harness in my opinion.
Old Feb 22, 2010 | 03:08 PM
jhammond_82's Avatar
Reject Papi
don't forget to get obd2A-obd1. or you can get a po6 chipped with vtec. sometimes you can get them dirt cheap, and pay a tuner 50 bucks to convert it to vtec. better than paying top dollar for an actual p28. know what i mean?
Old Feb 22, 2010 | 03:30 PM
Icon6 Re: sohc vtec ecu??
i got a freind that is goin to wire up the vtec for me i personaly dont know how electrical is my weak point and i agree for get tryin to buy a whole new wireing harness, I got another question when you make a mini me putin the vtec head on a d series u didnt have to tap the block for the oil just on the b series and one of my freinds told me you have to do it on the d series to so now im confused anyone have any info on that ?
Old Feb 22, 2010 | 04:55 PM
yes, once you remove your sohc head, towards the back between the 2 and 3 cylinders there is an oil jet that needs to be removed. just take a small screw and screw it in a little and pull it out.
got a question...what's the difference between obd2, obd2a and obd2b? if its definetly obd2a-obd1, i might have the jumper harness laying around. i will check and let you know.
Old Feb 22, 2010 | 05:01 PM
-__-'s Avatar
^^he is right. when u do the SOHC VTEC head on a NON VTEC block, you must remove an oil jet. research more on your swap and u willfind out. but as for the ECU, you can also use a P2P ECU from a 96-98 civic EX. it is obd2A so u dont need to use a jumper harness or anything.
@accord2civic2prelude: there is only OBD2A and OBD2B. for civics, OBD2A ends in 1998 and OBD2B begins in 1999. They are different and so are the ECU's.
Old Feb 23, 2010 | 04:06 PM
p2p ok if i cant come up with the money for a p28 ill look into that i would much rather the p28 but right now im straped for cash and gettin that and the jumper is alittle expensive but im in no hurry right now im still collecting all my parts so ill see where im at and see which way im goin to go
JDMjackyboy
May 31, 2011 07:03 PM
95JDM
Jul 16, 2008 06:47 PM
Bulli Kid
Jun 11, 2007 03:17 PM
sobe
Apr 17, 2005 04:38 PM
