1991 Accord Shift issue
Old Feb 22, 2010 | 12:07 PM
vcguy28's Avatar
New User
Icon3 1991 Accord Shift issue
I just bought a 1991 Accord LX, 4 door, auto tranny.
When the car is cold, it doesn't want to shift out of first gear. Once it is warm, it shifts fine. I can manually shift from 1 to 2 using the gear shifter, but in D3 or D4, it just stays in 1 until warmed up.
Fluid is fine--bright red, no burned smell or anything. Fluid level is good.
Any idea what I should look at?
By the way, 159K on the clock.
Old Feb 22, 2010 | 12:22 PM
Atreidies's Avatar
Default Re: 1991 Accord Shift issue
Probably a stuck valve or sensor in the tranny. Me personally, I would just manual it until it's warmed up every time. Seems like very little hassle to avoid changing the tranny, which would probably be cheaper than getting that one fixed. Especially if it is a non-issue once winter is over.
Old Feb 23, 2010 | 04:53 AM
vcguy28's Avatar
New User
Thanks for the reply.
That's kind of what I was thinking. It only takes about 5 minutes tops to get to the point of shifting properly.
Coming out of 1st, it shifts around 3K, but other than that, it seems to be fine.
Old Feb 23, 2010 | 04:58 AM
arkangel2487's Avatar
it wouldnt hurt to change the fluid with honda z1. unless u know its already in there. i had a prob going into drive. it would take a really long time. also make sure ur lines arent kinked
Old Feb 23, 2010 | 08:45 AM
vcguy28's Avatar
New User
The owner's manual recommends Dexron II. Can I still use the Z1?
If so, where do I find it? I'm sure auto parts stores carry it, but I've never actually looked for it so i don't know for sure.
Thanks.
Old Feb 23, 2010 | 09:44 AM
RallyAccord's Avatar
Goto a Honda dealership, they will have it, unless you live in the boonies haha
Old Feb 23, 2010 | 10:41 AM
vcguy28's Avatar
New User
Can I still use the Z1 though even though the manual says Dexron II?
Old Feb 23, 2010 | 04:52 PM
Atreidies's Avatar
Follow the owner's manual. Honda changes their formulas a little over the years.
Old Feb 23, 2010 | 07:24 PM
check with honda but they usually say dex is a temporary solution cus it will affect shift quality
jaygood2go
Apr 30, 2013 02:28 PM
steven.shutz
Sep 12, 2012 07:43 PM
masterkill455
Feb 20, 2009 10:37 AM
AzntaggeR
Aug 10, 2003 06:38 AM
