ctr pisons in a b18a block
Old Sep 6, 2002 | 09:48 PM
17secondcivic's Avatar
Default ctr pisons in a b18a block
i was wonderign if you could use ctr pistons in a b18a block, would the piston's compresstion be to high and thus creating valve lash?
thanks
Old Sep 6, 2002 | 09:52 PM
Default Re: ctr pisons in a b18a block (17secondcivic)
also i plan on useing a b18b head
Old Sep 6, 2002 | 10:07 PM
sgT's Avatar
sgT
valve lash isnt related to compression.
With CTR pistons your compression would be mid-high 11s.
Old Sep 7, 2002 | 12:49 AM
FastFoot's Avatar
Default Re: ctr pisons in a b18a block (sgT)
i thought ctr pistons in an ls block would be at least low to mid 12's:1..
Old Sep 7, 2002 | 01:09 AM
Drag R's Avatar
CTR's in a B18A/B w/ a GSR head is about 12.5:1,
with a B16 head, you looking @ 12.2-12.3:1
Nick
Old Sep 7, 2002 | 02:27 AM
ill phil's Avatar
Default Re: ctr pisons in a b18a block (Top Fuel ITR)
As far as machining of the rods to fit the pistons, what is needed? I'm not completely clear on this.
Old Sep 7, 2002 | 11:21 AM
sgT's Avatar
sgT
Default Re: ctr pisons in a b18a block (ill phil)
the small end of the rod is wider than the opening in the piston.
So you need to open up the piston a little bit to fit the rod.
SexyHatchie
Sep 24, 2007 12:13 PM
xracerGS-R
Feb 20, 2005 10:16 PM
