whats the best ecu
Old Feb 21, 2010 | 11:44 PM
tinyscivic's Avatar
Default whats the best ecu
as of right now my 95 civic is kinda stock but i want to upgrade the ecu to help out with some poew and all what can i do it is a 95 dx on mods so far are exhuast and headre , cold air intake , short shifter
Old Feb 22, 2010 | 12:06 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: whats the best ecu
the answer is............ the one thats tuned for your motor....
it would prob be best for you to stick with your stock ecu for now and maybe use a fpr to richen it up a little bit unless you wanna get it tuned (which seems senseless to me with a dx)
Old Feb 23, 2010 | 12:57 AM
chewyv's Avatar
pm4nudes
the best ecu? get a dc5 ecu and dont forget the kpro. there is also $7000 worth of supporting mods that should be done for it to be good.
Old Feb 24, 2010 | 09:12 AM
dpetro1's Avatar
keep the stock ecu, you do not have enough mods to require tuning.
Old Feb 26, 2010 | 12:09 AM
tinyscivic's Avatar
ok cool guy thank you
Old Feb 26, 2010 | 12:46 AM
pi Ka chuuu's Avatar
I have a b16a with some basic bolt ons. Intake, Header, Exhaust, Intake manifold. And I was running my stock ecu in my 93 si, which is a p28. It works best for me. I dont have heavy engine mods so I dont feel the need for an ecu upgrade. When you start doing some serious engine work or maybe a swap then you should consider a better ecu. Until then I think your fine.
Old Feb 26, 2010 | 04:59 AM
dpetro1's Avatar
p28 is the stock ecu for a 93 si but it is not the correct ecu for your b16 engine. you need a p30 or a chipped ecu reprogrammed with b16 maps for the car to run at its best. the b16 is dohc and better flowing. it also has a different compression ratio, its basically a whole different motor than the d16z6.
Old Feb 26, 2010 | 05:09 AM
Matt93eg's Avatar
I agree with the above, stick with your stock P06 ECU. Don't get "sold" on those "power making" chips you see all over the place, especially ebay.
With modifications the only REAL way to make power is via a dyno. And with the mods/engine you have right now that would be a waste of your time and money.
Stock P06 it is
Old Feb 26, 2010 | 05:16 AM
I'm sorry, I forgot to add in my statement that my car was tuned shortly after installing the engine and its bolt ons. I'm completely aware of the differences in both engines and that the p28 was programmed for the d16z6. I just wanted to make a clear statement that he should remain with his stock ecu and not expect to get his motor running correctly or more powerful by swapping it for another ecu.
Old Feb 26, 2010 | 05:19 AM
dpetro1's Avatar
dkboyny11
Sep 11, 2007 11:30 AM
maximedx
Jul 17, 2007 07:25 PM
Felliph3
Oct 20, 2006 01:56 AM
Sniper1st
Apr 11, 2006 05:02 PM
