help with foglight
look at this pix:
i put the fuse between the battery to switch.. every time i test it, the fuse blew... i remove the fuse n connect it directly to the switch... what u guys think??? if anything goes wrong... the light bulb going blow?
if it blows then you have a short somewhere leave the fuse in and test it with out the switch and see if it still blows if it does then you have something wired up wrong or the fuse is to small
The fuse is telling you something, that there is a problem. What it is like a 30amp?
You could take apart your fog lights and make sure they are installed correctly. I had problems with mine. You should do that. Its really easy to and you will learn how to install bulbs for when you need to.
First off you should be using a relay.
As mentioned, check how the switch is wired, it is easy to mis-wire an illuminated switch, start by disconnecting the switch ground and see if fuse still blows. 94
barone
Jun 4, 2011 07:21 AM
