need a type s oil pump modded for a k20z3 block
Old Feb 20, 2010 | 07:13 PM
iwill's Avatar
Default need a type s oil pump modded for a k20z3 block
like the title says need an oil pump modded asap 2 fit my z3 block hit me up if u can do this located in so cal
Old Feb 20, 2010 | 07:22 PM
KINGVEM^^ED6's Avatar
Default Re: need a type s oil pump modded for a k20z3 block
1st
Old Feb 20, 2010 | 07:35 PM
iwill's Avatar
cmon gotta get this k done help a brother out
Old Feb 20, 2010 | 08:13 PM
iwill's Avatar
ttt
Old Feb 20, 2010 | 08:14 PM
civic nation's Avatar
go to k20a.org
Old Feb 20, 2010 | 08:22 PM
iwill's Avatar
yeah im on right now its dead ill wait untill the morning just need info on who can do this
Old Feb 20, 2010 | 08:23 PM
probably blueprint or erl. how high are you trying to rev your motor
Old Feb 20, 2010 | 08:26 PM
iwill's Avatar
not too high 8500 i just need the bottom cut to fit block just like the k24 builds
Old Feb 20, 2010 | 08:37 PM
i think the mod is somewhere around 180
Old Feb 20, 2010 | 08:44 PM
iwill's Avatar
it frees up some hp also like 3 or 4 not much but its something plus my stock bump is huge the engine is on a stand and ready to go just need the pump to be cut
Old Feb 21, 2010 | 12:03 PM
iwill's Avatar
cmon nobody?
Old Mar 4, 2010 | 09:08 AM
k20GSR's Avatar
Why not use the Z3 pump?
Old Mar 4, 2010 | 09:20 AM
HaNgTiZZy's Avatar
i wouldn't waste my time with switching out for a type s pump. if you're planning on revving to 85 the stock pump should be fine. about it robbing horsepower is true but the Z3 pump also holds 3/4 more of oil in there so it will not cavitate from what i heard. use the 150-200 on something else like a 70mm tb that will actually help you. either way gl with your search k20a and 8thgen are your best bet
goldeg666
Apr 23, 2009 08:33 PM
dart2.2
Jun 21, 2008 06:11 AM
nighttrain33
Oct 3, 2006 07:30 PM
BoostedEgHatchFl
Oct 26, 2005 06:10 PM
infinkc
Jul 8, 2002 07:12 PM
