problems with 91 crx si
Old Feb 20, 2010 | 05:09 PM
g wheel's Avatar
New User
Default problems with 91 crx si
so my car wont start cause the battery is dead but if i jump it it will run so i assume that something is draning the battery? idk what tho i checked all the obvious connections and couldnt find the problem. also i have been check engine light problems the code says bad map sensor but ive changed it out like 4 times checked the connection and used someones ecu to find out if that was the problem but it wasnt, so its gotta b wiring rite? any helpful feedback would b appreciated thanks
Old Feb 20, 2010 | 05:18 PM
91hatchproject's Avatar
From: lancaster, ohio (pronounced "lankers uh-hi-ya")
Default Re: problems with 91 crx si
test your alternator, if its good, replace your battery.
My car was doing the same thing last week, changed battery, runs fine.
moving on now to the next problem
lol
Old Feb 28, 2010 | 09:14 AM
Justbooneit92cb's Avatar
New User
Hey check ur coolant temp sensor and then check ur iat that should fix ur map problem
accerat
Jan 14, 2015 10:19 PM
Hondasi88
May 12, 2010 08:27 PM
berts95ej
Jul 18, 2006 02:38 PM
EFMAN
Aug 31, 2005 08:56 AM
