Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
3 codes that popped up on my 03 Odyssey
Old 05-06-2010, 07:40 PM
Hondasi88's Avatar
Default 3 codes that popped up on my 03 Odyssey
I came home for a quick lunch, checked my mail and this happened once I started up the van
The "D" light was flashing and these codes popped up.
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
P0748 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
As I was driving back, I lost all power as if the alternator wasn't charging.
Any help would and will be greatly appreciated!
Old 05-08-2010, 07:48 AM
www.megameet.org's Avatar
Default Re: 3 codes that popped up on my 03 Odyssey
a bad battery/alternator can cause the ecu to throw codes when the voltage gets to low. Check the battery, then the alternator. replace whats dead. Clear the codes, I'm sure it's just from the voltage drop.
Old 05-09-2010, 05:59 PM
Hondasi88's Avatar
I changed the alternator and had the battery charged but something still isn't working right.
I need to find a good place to take this van to.
Old 05-09-2010, 07:24 PM
we need more info than "not working right" if you want help. Maybe some specifics.
Old 05-11-2010, 05:26 PM
Hondasi88's Avatar
The first problem is the charging issue. I changed the alternaor and battery but van won't keep a charge.
2nd i changed both o2 sensors and still pull up the same code. As for the flashing "D" light. Im guessing there is something bad in the sensor.
Old 05-12-2010, 04:20 AM
NDNV's Avatar
Check the Fuse #6 (15A) in the Driver's Under-Dash Fuse/Relay Box.
Old 05-12-2010, 11:23 AM
Hondasi88's Avatar
will do that in about 30 minutes!
thanks
Old 05-12-2010, 08:27 PM
Hondasi88's Avatar
thanks for the advice! I changed a few grounds and then changed the fuse and now it charges.........
thanks again!!!!!
accerat
01-14-2015 10:19 PM
wattynz
03-24-2012 10:24 PM
Stryk3r420
01-30-2010 05:35 PM
bengay
08-01-2009 08:45 AM
pacifico
09-18-2006 08:15 PM
Quick Reply: 3 codes that popped up on my 03 Odyssey
