Turbo Gsr Clutch Problems/ Freeplay
Old Feb 20, 2010 | 12:57 PM
TurboTeg332's Avatar
Icon2 Turbo Gsr Clutch Problems/ Freeplay
I jus changed my flywheel clutch (Stage 4) and pres plate 1900 lbs. Whenever I floor the car and it reaches full boost in 1st or 2nd the car jus revs up quick all way to redline.
Somethn is slipping but Im not sure what. I checked the pedal height of clutch pedal as well as the free play by measuring w a ruler. Both seem to be in specs. However when i push my foot down and the clutch pedal it seems like by the way it feels just going by feel that there is very little freeplay.
This is not a stock clutch so should freeplay not be the same as stock freeplay?
Could out of adjustment freeplay be causing clutch to slip ?
Please HELP !!!!
Old Feb 20, 2010 | 01:57 PM
masintegrafleet's Avatar
Default Re: Turbo Gsr Clutch Problems/ Freeplay
from what i know anytime you have a clutch thant is pucked it will not feel the same as a full faced one. with that agressive of a set up and turbo you are just most likely spinning the wheels not slipping the clutch.
Old Feb 21, 2010 | 08:43 AM
95 integra's Avatar
Yep, either you bought a cheap ebay clutch that is complete **** and can't hold the power or your spinning the wheels and can't tell the difference.
92b18csi
Nov 2, 2007 08:03 PM
MachAF
Mar 17, 2003 10:24 AM
MachAF
Mar 14, 2003 03:46 PM
Brett
Nov 15, 2002 01:18 AM
