HOW TO REMOVE AXLE FROM HALF SHAFT
Old Feb 19, 2010 | 03:10 PM
MIGPA26's Avatar
Default HOW TO REMOVE AXLE FROM HALF SHAFT
I have a 91 hatch with b16.
How do you remove the axle from the halfshaft?? do you pry i pulled and turned it and it dont come out?
any help would be greatly appriciated
Old Feb 19, 2010 | 03:11 PM
masterEF's Avatar
Default Re: HOW TO REMOVE AXLE FROM HALF SHAFT
the axle is the halfshaft
but shouldnt it slide out or something?
Old Feb 19, 2010 | 03:18 PM
MIGPA26's Avatar
i thought the halfshaft is the part that has 2 bolts that connects to the tranny and the axle plugs right into that..
this is the driverside..
Old Feb 19, 2010 | 03:28 PM
scottmog's Avatar
pry out slowly
Old Feb 19, 2010 | 03:30 PM
lunalink's Avatar
the half shaft bolts up to the back of the block. it has 3 bolts ( if i can remember)
and its for B series motors.take it out with the axle (if you can)
and slightly tap it with a hammer.
oooooooorr. rent a tool at autozone to take it out.
Old Feb 19, 2010 | 03:44 PM
MIGPA26's Avatar
i figure i was going to use a pry tool to take out axle
Old Feb 19, 2010 | 04:03 PM
masterEF's Avatar
i know im forgetting stuff ever since i traded my car
Old Feb 19, 2010 | 05:40 PM
beansandrice's Avatar
Just pop it out with a flat blade screw driver.
Old Feb 19, 2010 | 05:45 PM
mwaedow's Avatar
There are little "ears" on the tranny end of the shaft. They can be tricky, but use a pry bar, or two pry bars if you can, and with solid pressure, it will pop right out. There's just a little ring clip on the shaft that holds it snug inside the trans. you'll get it.
Old Feb 19, 2010 | 07:51 PM
Je2RiT's Avatar
a Pry bar works all the time for me.
As beansandrice stated a flathead screwdriver works too!(as long as its fat enough)
Old Feb 19, 2010 | 10:17 PM
MIGPA26's Avatar
I noticed the new axle has a ring that holed it in, so i figured im going to have to pry it out..
Old Feb 20, 2010 | 01:17 PM
MIGPA26's Avatar
i used a pry bar to take axle apart from half shaft thanks...
Tommy_Gunns
Apr 13, 2009 09:39 PM
EGPrelude
Jun 17, 2008 07:46 AM
HONDA RR
May 4, 2007 08:15 AM
djSALIX
Apr 12, 2006 09:20 PM
huepowered
Mar 27, 2006 12:33 PM
