URGENT! HELP WITH EXHAUST
Old Feb 19, 2010 | 02:20 PM
Manlion's Avatar
Default URGENT! HELP WITH EXHAUST
i bought an entire exhaust headers, hi flo cat and everything behind it.. its a srs and i decided to put it on today...i bought it off a kid who put it on for a week then took it off cuz he totalled his car.. it was on a 94 but mines a 97.. i have 2 02 sensors but there is no spot for me to put the 02 sensor after the catalyic converter.. WHAT DO I DO??
any input/help is appreciated thanks a bunch
Old Feb 19, 2010 | 02:28 PM
redbull-1's Avatar
Default Re: URGENT! HELP WITH EXHAUST
Get an oxygen sensor bung plug.
http://www.racepartsolutions.com/pro...rod=RPS-o2plug
Even the right size bolt will do. I recommend putting some anti-seize on it, just in case you even want to take it off for whatever reason.
Old Feb 19, 2010 | 02:35 PM
Manlion's Avatar
i dont have 2 holes one oxygen sensor
i have 2 oxygen sensors one hole lol
Old Feb 19, 2010 | 02:38 PM
redbull-1's Avatar
Sorry, misread it.
Go to a muffler shop, they can drill and weld on an additional oxygen sensor bung. Shop around by talking to the guys, as some guys will do it cheap, like $20.
Old Feb 19, 2010 | 02:40 PM
crx_91si's Avatar
uhhh....use your stock cat with the (2) oxygen sensor holes? that would be the most logical
Old Feb 19, 2010 | 03:03 PM
Manlion's Avatar
first of all umm theres one on the headers and one after the cat on the stock system not 2 on the cat..
second of all i have a hi flo cat the new piping is all 2.5 instead of the stock 1.75 i cant use my stock cat and its recked prob wont meet inspections so i dont want to
Old Feb 19, 2010 | 03:04 PM
Manlion's Avatar
Originally Posted by redbull-1
Sorry, misread it.
yea i figured that would be the only thing i might just do it myself in the case i just didnt kno if i could just unplug the sensor and still pass inspection
Old Feb 19, 2010 | 03:14 PM
crx_91si's Avatar
my bad i was thinking VW (my day job), lol....your right. Alright, drill a hole and weld a bung. Should cost you $25 at the most.
Or buy a test pipe off ebayw/ the #2 bung and space out the rear oxygen sensor so it doesnt cause the P0420 DTC. This is the set up i was running til i swapped engines
Old Feb 19, 2010 | 03:19 PM
Manlion's Avatar
i think thats what im going to doeither that or ghetto rigging it, cut a circle around the old 02 sensor and drill a hole into the new exhaust and weld the surround metal thats around the 02 sensor to the exhaust
Old Feb 19, 2010 | 03:35 PM
GhostAccord's Avatar
If your exhaust is Stainless Steel you will want to put a SS bung on there not mild steel. If it is a mild steel setup, you can cut out just the bung off the Cat if you want. It's probably still easier just to buy a Mild steel bung for $5-$10 and do it right.
Old Feb 19, 2010 | 03:37 PM
Manlion's Avatar
yea i guess thats true.. ill just have to buy the bung
thanks for the input
Old Feb 20, 2010 | 05:21 PM
4Door01Accord's Avatar
New User
Dang, ya'll got headers????? Like a V-8 Honda??
Old Feb 21, 2010 | 07:09 AM
NashvegasCg's Avatar
getting a new bung drilled is the cheapest and most time effective way to do it.
Old Feb 21, 2010 | 07:10 AM
Manlion's Avatar
lol
Old Feb 21, 2010 | 07:16 AM
Manlion's Avatar
Old Feb 21, 2010 | 07:22 AM
bakertime's Avatar
Don't do that, or you're asking for a CEL. The secondary O2 is there to make sure the catalytic converter is working, so it needs to be behind the cat.
The reason you only have one bung is because the 94 was OBD1, which doesn't use a secondary O2 sensor. However, OBD-2 cars (95+) do use them.
Old Feb 21, 2010 | 09:14 AM
Did you end up getting both O2 sensors hooked up? Can't see anything in your pic.
Old Feb 21, 2010 | 02:27 PM
Manlion's Avatar
nope couldnt get the old o2 sensor out its like its welded in.. ive tried everything.. i think i might just pick a new one up
Old Feb 21, 2010 | 03:32 PM
bakertime's Avatar
Anything exhaust related tends to get seized up like that...constant heating and cooling is tough on parts. Probably rusted into one piece haha.
Old Feb 21, 2010 | 04:15 PM
Manlion's Avatar
yea i tried everything, i kno lubricant is advised against because its known to clog the pores on the sensor but as a last resort i poured pb blaster and liquid wrench on it, let it sit, then stuck that **** in a vice and it still wouldnt budge even with 3 people pullin on it, it just started to strip
Old Feb 21, 2010 | 06:43 PM
I have one here but I don't even know if it word be worth the cost of shipping. It's probably 14 years old.
Old Feb 23, 2010 | 11:03 AM
Manlion's Avatar
lol thanks for the offer, but i just picked one up from autozone.. cost me 80$..
Old Feb 23, 2010 | 11:45 AM
What brand?
Some of the none OEM secondary O2 sensors heater circuits don't seam to work well/last long. Just an FYI! So if your CEL happens to pop on after a bit that is what you may expect to be the problem.
Old Feb 23, 2010 | 12:12 PM
Manlion's Avatar
What brand?
bosch
confused1569420
16
May 6, 2005 11:22 PM
breathinez
Aug 18, 2004 09:20 AM
chris@inlinepro
Jul 15, 2003 11:05 PM
