Honda Woesssssss.....
Old Feb 19, 2010 | 12:08 PM
hondamn1320's Avatar
Default Honda Woesssssss.....
I decided to separate this topic from my "build" thread, so I can get some clearer answers.
Link for reference: https://honda-tech.com/forums/showth...&highlight=gsr
Ok.. So I got the motor put together and running. Ran real strong for 2 weeks, then tragedy struck. Still unsure if it was due to the oil pump, or the dented oil pan, but the motor was starved of oil and spun a few bearings. I believe the cylinder walls may have been scared at the same time. The crank, thank god, wasn't scarred, at least anything you could see with your naked eye. So, I threw in some new bearings because I NEED the car running.
There's still a slight knock under slight load (from 1200 - 1500ish), but goes away after that. This leads me to believe it will only get worse as time passes on.
So here is where I need advice. I've read that some people have had trouble with this particular setup up. I'm looking to rebuild and DON'T want to do it a 2nd, or 3rd time.
Current setup:
GSR block
LS Crank
OEM LS rods
PR3 pistons (stock bore)
Oil squirters were bent to clear crank
Should I keep this block, bore it, throw in some eagle rods and rs machine(?) pistons, have it balanced and run it with hope it'll stay together. Or, should I just go with an LS/Vtec setup?
Right now, I'm leaning more towards the LS/V setup up. Both are available to me. I was thinking of boring the block to B20 spec (84mm?).
Setup I'm thinking about:
LS block
OEM LS crank
OEM bearings
OEM oil/water pump
Eagle rods
84mm wiseco pistons (11.5ish compression)
What would be the best route to take? I don't want to go through this again (at least anytime soon).
If you need anymore info, I'd be glad to give it.
Old Feb 19, 2010 | 04:28 PM
Default Re: Honda Woesssssss.....
What to do...
Old Feb 19, 2010 | 04:34 PM
00Red_SiR's Avatar
All Motor Mentor
You'd need to have the block sleeved to be able to bore out to 84mm but this would be a nice setup.
Old Feb 19, 2010 | 04:43 PM
Absolutely have to?
My friend JUST sold his B20 block.. D-D-D-Dammit man.. :[[ That kinda puts a bump in the plans.
So what would be the ideal bore to open up the LS block to?
Old Feb 19, 2010 | 05:08 PM
00Red_SiR's Avatar
All Motor Mentor
The most you can go would be 82mm.
Old Feb 19, 2010 | 07:31 PM
Well, it's better than nothing.
Old Feb 20, 2010 | 08:45 AM
00Red_SiR's Avatar
All Motor Mentor
possibly but if anything goes wrong, that block can't be bored again.
Old Feb 20, 2010 | 11:03 AM
Understandable.
Which is why I want to use an LS block this time around. Cheaper and easier to find.
Old Feb 21, 2010 | 12:01 AM
81.5mm 10.5:1 Wiseco pistons in a GSR block with LS crank and rods would yield somewhere around 11.7:1? Just want to make sure before I commit to the purchase.
Old Feb 21, 2010 | 05:42 AM
00Red_SiR's Avatar
All Motor Mentor
It will only go up by about .2, all things being equal, so 10.7:1 however, measuring and cc'ing is the only way to have 100% accuracy.
Old Feb 21, 2010 | 08:22 AM
I was a little out of it last night.. But it would only yield a ~11+ compression ratio if the pistons are for a B16 with stock stroke, correct? I figure because utilizing B16 pistons will yield a compression ratio in that vicinity.
Old Feb 21, 2010 | 09:12 AM
Just going to go with a 82mm PR3 RS Machine piston.
Old Feb 21, 2010 | 09:42 AM
00Red_SiR's Avatar
All Motor Mentor
If the 10.5:1 was in a B16a then installing those pistons in a GSR block with LS rods and crank would increase compression roughly 1.5 over that to about 12:1 or so.
Old Feb 21, 2010 | 03:01 PM
Woah... even better. Lol.
Last question (for now), are the RS Machine pistons compatible with Eagle rods?
Also, thanks for your patience and help. It's VERY appreciated.
Old Feb 21, 2010 | 03:35 PM
93egSLEEPER's Avatar
YES. great pistons
Old Feb 21, 2010 | 04:01 PM
Thanks. Buying them right now, then.
Old Feb 22, 2010 | 09:26 PM
I PM'd the seller on Ebay (Droopie888) and asked him if they were compatible with eagle rods and he told me, no, they were designed for "stock style" rods.
Ebay listing: http://cgi.ebay.com/ebaymotors/ws/eB...2842&viewitem=
hydell3
Jul 19, 2014 06:48 PM
93egallmotor
18
May 6, 2008 10:51 PM
ThatsMyEG
10
Aug 20, 2005 05:13 PM
Sacker90
May 21, 2005 06:17 AM
project dc2
Jan 26, 2005 09:46 AM
