Car wont stay on unless You "HOLD" key in turn on position
Wanted to know if anyone had this problem.
My car wont stay running unless i hold the key in the start position once the car is on. if it bounces back the car will die. the car will start up everytime but once in a while this will happen. Installed a viper 5901 but this issue didnt start until after the swap was done.
i have an Ek with a 00 b18C swap.
checked the wires and nothing that i can see.
Thanks!
Thanks!
the ignition switch, is the assembly you insert your key into, its attached to the steering column behind the steering wheel, i believe thats what needs to be replace, that would mean you'd also need a different ke for your new switch
http://techauto.awardspace.com/ignitionswitch.html
Googled it and found that, should be enough info there.
YOU ARE MY HERO!!!
safedriver
May 25, 2012 02:48 AM
badfish2282
May 15, 2009 08:45 PM
91hob20hb
Jul 17, 2004 11:16 AM
