Suspension & Brakes Theory, alignment, spring rates....
ASR subframe and sway bar question
Old Feb 18, 2010 | 11:31 PM
phan222001's Avatar
Default ASR subframe and sway bar question
I installed the asr rear subrame brace on my ek and trying to install the itr rear sway bar. My question is i have the megan rear lower control arms will i have a problem with lining up the bar with the holes on the control arm for the sway bar link?
Old Feb 19, 2010 | 02:26 AM
Meoshe's Avatar
Default Re: ASR subframe and sway bar question
Only you can tell without pictures, although if the lca has more than one endlink mounting hole you'll be ok. If it only has one mounting position you will most likely have to get si styled enlinks or heim joint styled ones.
Old Feb 19, 2010 | 03:09 AM
bmoua's Avatar
no matter what, you'll need si endlinks!
Old Feb 19, 2010 | 07:53 AM
kristo's Avatar
Loved
This is not correct.
SI style endlinks ('balljoints') do not fit an ITR/EG style swaybar: the endlink mounting of those sways is not flat shaped like an SI or EK9 swaybar but 'tunnel' like.
You can only use ASR/Blox style endlinks ('spherical endlinks') which have longer bolts that together with OEM or ASR (metal) swaybar link bushings will fit the ITR/EG style swaybar.
Lining up of the swaybar will not be a problem.
Old Feb 20, 2010 | 01:33 AM
Meoshe's Avatar
Si endlinks will fit integra swaybars, I have gsr rear sway with si endlinks for sale that I used ony my car.
Old Feb 20, 2010 | 02:51 AM
JLCivixHBDX's Avatar
If you want to use Si link kit with ITR & TEG sway bar
http://hondamarketplace.com/showthre...2#post41637772
Old Feb 20, 2010 | 08:48 AM
kristo's Avatar
Loved
These metal bushings you always need to use (or OEM ones).
This could clearly do with a longer bolt.
This is how much an SI endlink bolt normally sticks out:
Old Feb 20, 2010 | 02:42 PM
phan222001's Avatar
thanks everyone i just ordered the blox end links and waiting for them to come in hopefully everything works out
on-site ej1
Apr 25, 2010 03:42 PM
jtl
Apr 1, 2004 04:24 PM
KOME
18
Jun 14, 2003 03:22 PM
GokuSSJ4
10
Mar 17, 2002 11:11 PM
tFUnK
18
Feb 8, 2002 11:24 AM
