91 civic running problems help!
Old Feb 18, 2010 | 02:56 PM
krobie's Avatar
Default 91 civic running problems help!
I got a civic with a b18a1
put a stock intake manifold on to replace the b16 one.
im having high idle 3k-4k
but wen i go to give it gas, no power
throwing codes for 15, 5, 7, 6
threw code 6 before i replaced intake manifold
fuel pressure at almost 70!
Old Feb 18, 2010 | 03:00 PM
REAPER101's Avatar
Default Re: 91 civic running problems help!
hmmm i had a simalar problem is your wiring all good what about ecu do you have the right 02 sensor
Old Feb 18, 2010 | 04:21 PM
krobie's Avatar
wires look fine i dont think i have the vac set up right cause i only got a map sensor and one black canister by it, integras have two. isnt 70 psi for fuel pressure too much? it does have a built bottom end but the high idle and no power when giving it gas is my problem
Old Feb 19, 2010 | 03:57 AM
REAPER101's Avatar
yea 70 thats up there well i meant was the wireing done right and yea i could see there being a vacum prob hmmmmmm
Old Feb 19, 2010 | 04:32 AM
krobie's Avatar
well idk if it was done rite, i didnt do it. it was running good before the im swap but the reason i did the im swap cause my b16 im that was on there didnt have a ficv on it
cbabyby
Apr 19, 2007 04:44 PM
B16Jacques
Jul 4, 2006 02:37 PM
Maroonda9
Jun 27, 2006 09:40 AM
janz3n
Apr 11, 2006 08:06 AM
pro1342
13
Sep 13, 2005 12:01 PM
