Low Offfset Wheels Question on EG 4 door
I got some Spormaxx 501's 15x8's +15 offset. 195/50R15's. Was looking into SKunk2 Front and Rear camber kits. Front upper control arms with adjustable balljoints and Rear with adjustable upper control arm. I also got Full Ksport coilovers. Would this be enough to clear the wheels into the fender wells? Or should I look into fender rolling as well? Advice would be great, Thanks!
You will probably want to roll and pull the fenders no matter what. Doing so, would allow running less negative camber. Unless you really like the "mad camber" look.
Also, just to throw this out there, but 195/50-15 sized tires are not approved for use on 8" wide wheels, and could be unsafe to run.
