problems with b18C6 swap in EG6
Old Feb 18, 2010 | 09:48 AM
haukurn's Avatar
Default problems with b18C6 swap in EG6
hi i was taking my first drive in my newly swapped civic EG6 (b18C6 engine/tranny)
and i ran into few problems. hope you can help !
1. the speedometer doesnt work, and therefore no VTEC! my VSS is good ! worked on my b16 engine fine!
2. the CEL is shining bright, i tried to check for error codes from ECU, but the CEL wont blink.
3. after the short drive, i notice there was a water steam coming from the engine bay, and i opened it and there was water drops and steam on the radiator/gearbox, (im using b16a2 radiator, is it too small for b18c6 ?)
please help me, i want to feel the vtec of ITR power !
Old Feb 18, 2010 | 01:46 PM
cpearson's Avatar
New User
Default Re: problems with b18C6 swap in EG6
Me too! Good luck man.
Old Feb 19, 2010 | 03:21 AM
haukurn's Avatar
hehe yep!
BUMP!
Old Feb 19, 2010 | 07:34 AM
Relic1's Avatar
the steam - most likely a leak in the upper hose or somewhere near there. OR you had water on the engine before the drive. Keep an eye on the coolant level.
the CEL - which which ECU are you using?
no speedo - which engine harness are you using?
Old Feb 19, 2010 | 11:19 AM
haukurn's Avatar
im using p30 ecu with b16a2 map for now.
engine harness-> b16a2
Old Feb 19, 2010 | 12:12 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
almost sounds like your ecu is fried. most of the time when the cel is solid it means theres something messed up in the ecu.
as for the radiator a b16 rad will work just fine for you.
Old Feb 19, 2010 | 12:25 PM
haukurn's Avatar
i dont think that the ECU is fried, especially because the CEL blinked when i disconnected the IAT sensor.. and gave me CODE-10, wich is IAT sensor.
Old Feb 21, 2010 | 04:32 PM
haukurn's Avatar
about my tach not working,, what thing should i double check
my vss and ?
Old Feb 21, 2010 | 04:36 PM
promotor's Avatar
i think something is wrong with your ecu.
Old Feb 21, 2010 | 08:28 PM
Relic1's Avatar
solid CEL on a car that blinks for a known code - do you have the service jumper in place at all times?
b16a2 engine harness does not have the tach line from the distributor to the shock tower plugs, in that car the tach is driven by the ECU. Run a new wire from the blue wire at the distributor to the blue wire at the driver's shock tower.
Old Feb 22, 2010 | 02:45 AM
haukurn's Avatar
i cleaned the VSS, and no the speedo is working but no vtec, im going to clean the vtec screen and solenoid
codenamezero
Aug 7, 2011 12:42 PM
crispyallen
17
Apr 15, 2008 06:04 PM
Sohc Driver
Mar 3, 2003 08:17 AM
Sohc Driver
Mar 1, 2003 01:01 PM
