Need help with conversion please
Old Feb 17, 2010 | 09:02 PM
kleeg9's Avatar
Default Need help with conversion please
I have a 98 ek civic which sarted out as a 1.6 sohc vtec. I had a 92 dohc vtec jap engine and gearbox and decided to put it in the ek. I got a 98 ek sir loom and used it. So the engine is in now and the car is running but the problem is the altenator is not charging the battery and the car wont heat up like it should.. Did anyone have any of these problems before??? thanks in advance
Old Feb 18, 2010 | 12:32 PM
mouab18c1's Avatar
Default Re: Need help with conversion please
maybe your alternator went bad??? re bleed your coolant system and check if your thermostat got stuck open
Old Feb 18, 2010 | 07:35 PM
smileydub's Avatar
check the alternator with a voltage regulator and see what its putting out then check it at the battery
wing.jai
45
Sep 2, 2011 06:39 PM
tonys2k
Jul 16, 2010 06:37 AM
civic*chick98
Dec 15, 2009 08:01 PM
Cras-Delsol
Jul 16, 2008 05:59 PM
RACEPAK
May 23, 2005 04:20 AM
