no pressure in brake system when car is on/ vacuum leak?
Old Feb 17, 2010 | 09:00 PM
slamLOWnBANGIN's Avatar
Default no pressure in brake system when car is on/ vacuum leak?
i just finished my brake line tuck and bled the brakes, and the pedal feels fine when the car is off but when i turn the car on, there's no more pressure behind the pedal. does this sound like vacuum leak or a bad cylinder or what?
i have no leaks from my prop valve or my brake lines. and the only vacuum line i can think of that i've messed with is the brake booster line, which i trimmed much shorter but made sure i kept the valve inside with the arrow on the line pointing the correct way.
Old Feb 17, 2010 | 09:15 PM
Schister66's Avatar
Man U FTW
Default Re: no pressure in brake system when car is on/ vacuum leak?
Was everything functioning normally before the line tuck? I assume yes, but i had to post something...I am pondering this and will let you know when something of value comes to mind
Old Feb 17, 2010 | 10:01 PM
yea,everything before was basically all stock with like 200,000+ miles on the motor, but ran strong. thanks for posting though. lemme know if you think of something.
Old Feb 18, 2010 | 04:02 AM
97twodoor's Avatar
It sounds like ou need to keep bleeding out the lines. When the car is off the pedal is hard, but as soon as you get some vaccum assist the pedal gets soft right?
Old Feb 18, 2010 | 04:35 AM
yea. so keep bleeding it? can you tell me the correct way to bleed?
Old Feb 18, 2010 | 04:39 AM
97twodoor's Avatar
Then it sounds like you've still got some air in there. Keep chasing it out. The correct way to bleed is to start at the furthest line from the MC (RR line), then the next shortest until you're done. So start at the RR line, then go to the LR, RF, LF.
Old Feb 18, 2010 | 02:46 PM
i will try that and see how it goes. thanks for the help. i'll post afterwards.
Old Feb 18, 2010 | 03:01 PM
bobbyeg6's Avatar
BRAKE Booster???????
Old Feb 18, 2010 | 03:06 PM
what about it?
Old Feb 18, 2010 | 03:07 PM
speedooo's Avatar
pressure when the cars off means the check valve is working...so no vacuum leak.
Old Feb 18, 2010 | 03:21 PM
okay thanks. atleast i know i dont have a leak. so i should just continue to bleed the system right?
Old Feb 19, 2010 | 03:55 AM
97twodoor's Avatar
Yep just like i said.
wgbm92
Feb 17, 2013 05:18 PM
danedoremus
May 23, 2012 04:39 AM
Fuster_Cluck
Mar 9, 2008 04:41 AM
Pman92
Sep 19, 2007 04:59 PM
TypeDC4
Oct 23, 2003 05:13 AM
