Engine shampooing
Old Sep 6, 2002 | 03:26 PM
VTECTIME's Avatar
Default Engine shampooing
How do you go about shampooing your engine? What things do you use and can you actually make your engine look substantially better?!
Old Sep 6, 2002 | 06:38 PM
deepnite's Avatar
Default Re: Engine shampooing (VTECTIME)
put in a spray bottle 50% simple green and 50% water..spray on and let sit for 5 min. then rince off..for some tougher spots use a soft brush and avoid spraying directly on electrical circuts
Old Sep 6, 2002 | 06:53 PM
4gvtec's Avatar
o.k people ill let you in on a little secret.really a big one.the best thing to use is ,are you ready oven cleaner!!!!!!!!!!!!!!!!!! no one knows this.IT DOES NOT HURT THE PAINT!!!!! THE ONLY THING IT DOES IS DULLS THE ALUMINIUM!
I HAVE PICS TO PROVE IT!
[Modified by 4gvtec, 3:54 AM 9/7/2002]
Old Sep 6, 2002 | 07:10 PM
DB5000's Avatar
Default Re: Engine shampooing (4gvtec)
i've heard this works
Old Sep 6, 2002 | 07:55 PM
hoya_10fintec's Avatar
Default Re: Engine shampooing (DB5000)
ya... some people use those... really I have done it couple times... it worked...
Old Sep 6, 2002 | 08:04 PM
wHOAlly's Avatar
Default Re: Engine shampooing (hoya_10fintec)
best cleaner ive used, and ive used most of them, is the GUMOUT STEAM CLEAN, comes in 2 pack, great ****, comes out REALLY nice w/o scrubbing or touching it, comes out even cleaner if u take a brush to the high deposit/dirty areas.
Old Sep 6, 2002 | 08:24 PM
granada_sun's Avatar
Default Re: Engine shampooing (AkumaY)
Gunk Engine Cleaner works well, good for the grime and grease/oil spots. Just spray heavy coats of foam, brush it, then rinse off.
Old Sep 6, 2002 | 08:43 PM
93SSPHatch's Avatar
Default Re: Engine shampooing (Dark_Sol)
Is it necessary to cover the electrical connections? I know that when my old 84 Corolla engine got water in the dist. cap, the car would idle so rough until it dried over night.
Old Sep 6, 2002 | 08:49 PM
Default Re: Engine shampooing (93SSPHatch)
It helps, using electrical tape (cause it holds stronger than masking and wont leave the sticky crap like duct tape, tape plastic around the distributor, or be careful not to drench the electricals and fuel lines/injectors.
This is also a good time to check the seals on the plug wires to make sure they dont leak into the plugs
[Modified by Dark_Sol, 12:53 AM 9/7/2002]
Old Sep 6, 2002 | 10:40 PM
skunk2unerz's Avatar
heres somthing you could do if you have an air hose. Once you clean the engine (what ever you used to cleen it) after the cleen- start the car and let run. While the car is running use the air hose to blow excessive water from the engine bay. That way you dont have to worry about the water..
NOTE: Try not to spray the distributor or electrical parts to long. Its not a problem if you briefly wash it.
Midori Green
17
Apr 27, 2007 02:06 PM
Civic Hybrid
May 15, 2006 09:24 AM
imaginary17
Apr 1, 2004 09:22 AM
DevinW
Aug 28, 2002 09:02 AM
