Problem starting car
Old Feb 17, 2010 | 06:21 PM
RomesEM1's Avatar
Default Problem starting car
Im starting to have difficutly starting my car...i kinda have to give it gas and hold the rpms steady until it can stay on on its own. almost like lack of or too much gas?? any help
Old Feb 17, 2010 | 06:23 PM
RomesEM1's Avatar
Default Re: Problem starting car
btw car is 99 civic si with b18c5 head, ctr cams, type r IM. new Dizzy, msd spark plug wires and ngk 7 plugs. new fuel filter, same old fuel pump, and injectors <--could it be them
Old Feb 19, 2010 | 11:18 AM
delsolproblems's Avatar
First make sure you have good spark at each plug wire. If you do, check the MAP sensor output voltage at idle after the car has reached normal operating temperature.
Old Feb 19, 2010 | 12:10 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
sounds like an issues with your iacv. is the car throwing any check engine lights?
Old Feb 19, 2010 | 12:40 PM
Jockone's Avatar
Check the coolant temp sensor,I had the same problem with a type R swap into a 2000 Si it was giving a code 6.
antiJDM
Jun 3, 2011 09:04 AM
Matt_EH2
Jan 16, 2010 02:54 PM
bobbyjr
Nov 20, 2007 07:05 PM
ZWK
Mar 27, 2007 05:50 AM
1BadDC2
Jan 17, 2004 06:36 PM
