is open header bad for all-motor???
Old Feb 17, 2010 | 02:27 PM
hellajdm333's Avatar
Default is open header bad for all-motor???
i would like to get the qtp cut out but some people say its bad for na cars? just wanted to hear what you guys have to think!???
Old Feb 17, 2010 | 03:18 PM
88Hatchy's Avatar
Default Re: is open header bad for all-motor???
It's not "bad", you just have to have it tuned.
Old Feb 17, 2010 | 03:36 PM
tune? for a cut out? y?
Old Feb 17, 2010 | 04:18 PM
Teamdiesel's Avatar
I asked the same type of questions when I first came on here, as you ask now. Simple put...you will need to retune your ECU's fuel and ignition parameters for almost any change you make to your setup, for maximum power output. Sure you can run the cutout just like that, but you will gain more power of tuned .
Old Feb 18, 2010 | 03:37 AM
how much cash we talkin to get a tune???? i live in wa state and were would you guys reconmend i get a tune????
Old Feb 18, 2010 | 04:25 AM
kulo's Avatar
my long tube header cracked open header
due to the lack of support?
Old Feb 18, 2010 | 08:21 AM
white.'s Avatar
Get tuned by Rich at Fluid Motorsports in Tacoma. Great guy and service, he charges about 275 flat rate and changes spark plugs and compression test and everything I believe.
editted.
Old Feb 18, 2010 | 08:34 AM
ilikehonda's Avatar
Originally Posted by white.
Get tuned by Rich at Fluid Motorsports in Tacoma. Great guy and service, he charges about 275 flat rate and changes spark plugs and compression test and everything I believe. Also, I believe you should be running stronger springs and retainers for open header but don't quote me on that.
why would you need stronger springs and retainers to run without an exhaust?
Old Feb 18, 2010 | 09:34 AM
white.'s Avatar
Sorry, I got mixed up with something else. Post has been editted.
88Hatchy
Engine Management and Tuning
Apr 16, 2010 08:47 PM
Nikos
Sep 29, 2005 07:56 AM
jakscivic
Apr 30, 2005 04:20 PM
dkim48
Honda S2000
28
Feb 9, 2005 10:17 PM
speedyonez
Nov 22, 2003 04:16 PM
