dash lights out?!
Old Feb 16, 2010 | 09:29 PM
fenix4o9's Avatar
Default dash lights out?!
was driving home the other night started my car and turned on the head lights. but no dash light or heater control back-light came on! radio still works and is on so i know its not a fuse. unless my fuse panel lies to me!!!
someone told me to check dimmer switch but i didnt know dimmer switch controls heater control backlight? does it?
let me know guys thanks
Old Feb 16, 2010 | 10:32 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: dash lights out?!
the dimmer wheel does control all of that, and is a common part that fails. So is the left combination switch (the stalk on the left of your steering wheel for the lighting). The dimmer switch is not terribly expensive. The left combination switch, however, is about $100. between those 2 parts, i would bet money one of them is causing the issue.
My experience has been that the left combination switch fails more often than the dimmer, but that is with a sample set of 2. you may look into the manual to see how to test each piece before blowing the money on one or the other.
incidentally, i have a dimmer switch for sale if you are interested. you can check out my FS page for more info..
Old Feb 16, 2010 | 10:56 PM
fenix4o9's Avatar
thanks for the info i wanted to buy ur switch but mine is horizontal and the one you have for sale is vertical ...damn
Old Feb 18, 2010 | 10:15 PM
fenix4o9's Avatar
update it was the combo switch aka headlight switch i did the tut. that someone linked to me on here and i cleaned it now it works hurray!
thanks for the help!
cmwalker
Jan 17, 2014 12:06 PM
Silvertune
11
Apr 15, 2012 09:20 PM
cityslicker1606
Sep 5, 2007 12:33 PM
Basically
Mar 6, 2005 08:58 PM
integra-modder
Apr 25, 2003 04:32 PM
