your thougths on this problem i am having
Old Feb 16, 2010 | 07:09 PM
redraven_k6's Avatar
New User
Default your thougths on this problem i am having
the car is a 98 Accord LX F23 motor, the problem it is having is that when the throttle is pressed down hard, it will stall, if its feathered really lightly it will rev and not stall.this is when it in park, when it is in drive, and you give it gas it will stall. i pulled the codes and one was a tps and o2 sensor so i replaced both, now there are no codes and the car still stalls.
i have installed a newer throttle body with a stock tps, that i got form a salvage yard. cleaned out egr and icv, there is spark and there is fuel.
when i get it to rev it will go to about 4 grand then just bog down and stall.
driving it is nearly impossible, if i cant get the throttling right, it just stalls,
i don't know what else to check.
any help on this issue will be very much appreciated.
Old Mar 17, 2010 | 08:46 PM
bakwudzgurl's Avatar
TRIAL USER
Default Re: your thougths on this problem i am having
please let me know what this is as my car just started doing this also....thats if I can get the car started.! I just changed the crank pulley,bolt/washer and had to buy a special tap because the threads were a tiny bit messed up from the old one flying off. when I went to start it after work was done it didnt want too,so we checked the plugs and wires. I really have a feeling and almost hope it's a fuel problem, dirty fuel/water etc...
Old Mar 17, 2010 | 08:51 PM
slomofo's Avatar
GDD Member
Change your fuel filter yet?
Did you adjust the TPS properly? (0.5V closed & 4.5V WOT)
MAP sensor working properly?
Old Mar 18, 2010 | 05:27 AM
pparr05's Avatar
In addition to fuel filter and other suggestions from slomofo, couldn't a clogged catalytic converter also cause stalling? Like the proverbial potato stuffed into the tailpipe as a prank?
Old Apr 19, 2010 | 10:26 AM
fatarss80's Avatar
check the plugs on the tps ant the map sensor mine did the same thing when they were reversed the map plug on mine is grey and the tps is blueish
Old Apr 19, 2010 | 09:07 PM
phootbag's Avatar
The TPS isn't adjustable on this throttle body. I tend to agree with the swapped MAP and TPS connectors. I have seen this before. Also, funny thing is, the values aren't so out of whack, so a DTC usually won't set. Way to go Honda...
ITR010342
Acura TSX
Jun 23, 2010 08:45 AM
arospeedintegra
May 30, 2008 01:20 AM
LOGONZOJLS
Jan 29, 2007 02:26 PM
3k9civic
Sep 15, 2006 08:45 PM
djtony5
Aug 21, 2005 02:42 AM
