Using starter to remove harmonic ballencer bolt.
Old Feb 16, 2010 | 05:19 PM
honda_S's Avatar
Default Using starter to remove harmonic ballencer bolt.
What do you think of this method? If you don't know what I'm talking about u can find like 5 videos on YouTube.
Basicly I have tried 2 diffrent impact wrenches. 1 was a Matco 1/2 inch and the other is one I just picked up at lowes for 180$ that says it does 600ft/lbs but both failed. So I'm thinking this might be my best bet but I don't know how safe it is or what dammaged I might cause
Old Feb 16, 2010 | 05:37 PM
SPOOLINmatt's Avatar
Default Re: Using starter to remove harmonic ballencer bolt.
i dont think it will work. Best bet is one of those impacts youve used and a torch to heat up the bolt red hot. Works everytime. Might take some effort to find and borrow a torch, but its worth the trouble. Im not talking about a hand held propane torch either.
Old Feb 16, 2010 | 06:10 PM
honda_S's Avatar
It does work u can find videos on YouTube. Yeah I already tried the propane but it doesn't get hot enough but I don't know where to find a o/a torch
Old Feb 16, 2010 | 06:17 PM
non-VTEC's Avatar
i do it on some trucks at work when i need to remove the bolt and there is no room for an impact gun....it's not the best way but it seems to work.
BUT.......i don't know how you will plan to pull it off on a honda engine that cranks/spins counter clockwise. mmmm...
Old Feb 16, 2010 | 06:38 PM
yeah i just thought about that, you cant do it on a honda.
/thread.
Old Feb 16, 2010 | 07:32 PM
slowhitEJ1's Avatar
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
(^^^ not THE tool sold at sears, but its the same style-couldn't get the link to work through sears)
http://www.jegs.com/i/Moroso/710/61805/10002/-1?CT=999
either will work, and you'll need them to be able to tighten it back.. trust me, 3 bolts, 2 pullies, and 1 motor later, i finally learned my lesson.. no amount of thread lock will keep it on if it's not torqued properly..
google "honda crank pulley tool" and go to shopping.. theirs a lot of styles, some as low as ~30 bucks..
EDIT: Snap-on makes one under the Blue Point name i believe, though I can't find the part number.. help?
shermanyang
Honda CR-V & Element
Aug 21, 2013 07:35 PM
xxliljonxx1
Mar 1, 2012 04:02 PM
honda_S
Feb 16, 2010 07:33 PM
00DC2
Jul 22, 2009 06:18 PM
hellas
Jan 21, 2003 12:33 PM
