Jumping VTEC oil pressure switch
Old Feb 16, 2010 | 03:44 PM
turb0teg's Avatar
Default Jumping VTEC oil pressure switch
I've never dealt with wiring diagrams, just the basic matching colors for headunit hookups and systems. As far as reading the ECU pin diagrams, I'm dumb as a rock and not afraid to admit it. Luckily, I somewhat make up for it in the mechanical aspect.
Just to make sure I'm doing the correct wires (I know to jump pins A4 and D6, I'm referring to the colors), in my 1992 Civic Hatchback CX, I need to jump these two wires:
A4- Orange (White Stripe)
D6- Orange (Black Stripe)
Not looking for anything special, just, "Yes, your colors for those wires are correct for those pins" or "No, you need to jump the XXXX color wire of A to the XXXX color of D."
Thanks for the help!
Old Feb 16, 2010 | 05:26 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Jumping VTEC oil pressure switch
Old Feb 16, 2010 | 05:59 PM
turb0teg's Avatar
Thanks for that. I see exactly where it says the wire colors to distinguish if I read the same picture correctly all 26 times I've seen it.
Old Feb 16, 2010 | 10:43 PM
sbpphoenix's Avatar
92? you're already wired for vtec. just get an ex/si harness.
Old Feb 17, 2010 | 06:07 PM
Technical Hero
A4=Orange/White
D6=Orange/Blue
This is according to the 92-95 factory service manual
Old Feb 24, 2010 | 10:12 AM
turb0teg's Avatar
SBPPhoenix, I was trouble shooting as to why vtec wasn't working.
HondaPartsHero, thanks for the help!
Old Feb 24, 2010 | 10:59 AM
bobbyeg6's Avatar
i got a 20 but there is no eld on my car?? 92 eg6 but it takes 2 long flashs. after i hooked up my v-tec.
Old Apr 7, 2010 | 05:34 PM
overrev_it's Avatar
can i t-tap the solenoid wire "Orange (White Stripe)" and run a wire from the T directley to d6?
will this work without the oil pressure switch?
Old Jul 30, 2015 | 08:17 AM
xChrizcrozzx's Avatar
I did this and still no Vtec, Am I supposed to take A4 And D6 out the Harness then connect them or just bridge them while connected to the ECU??
DTA-Zombie
Aug 1, 2008 11:14 AM
strictly.business
Dec 27, 2006 06:38 PM
Who Said
Apr 4, 2003 11:14 PM
civicracer1993
15
Mar 26, 2003 05:23 PM
fasterthenmost
Mar 19, 2003 12:37 AM
