where on the p28 ECU do i run the wires for VTec solenoid and oil pressure?
i just put a d16z6 in my cx hatch and i need to wire vtec in .. where do the wires from the solenoid go and where do the oil pressure wire go? also on the solenoid there is 2 wires does it matter which goes where or can either one go to either spot? one is on the top and one on the bottom..
thanks
i have a CX harness so no vtec wires are in it..
thanks
Banned
Re: where on the p28 ECU do i run the wires for VTec solenoid and oil pressure? (civicracer1993)
If your car does not have vtec, 2 more wires must be added. A yellow wire with a green stripe for the vtec solenoid can be found on the engine harness and must be pinned in at A4. The vtec oil pressure sensor can be found as a blue wire in the harness and must go to D6.
one of the oil pressure wires is ground so just use the one the thermostat housing, the other wire goes to A4 plug
then vtec solenoid goes to D6
also to add, since your car is a CX your 02 will need to be changed to 4-wire type (from the one wire)
one of 'my' pdf scans with OBDI diagram
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Re: where on the p28 ECU do i run the wires for VTec solenoid and oil pressure? (josups)
ok there are already other wires in them spots on my ECU plug should i just tap into them.. ? and that diagram is correct right
the d16z6 does not have a knock sensor that needs to be wired in right? also which wire on teh Vtec solenoid goes to the ecu and which goes to the ground the top or bottom wire?
This may help too...
ok yea thats what i thought it was, but one question.. why does it show the oil pressure as having 2 wires when mine only has 1 ? also which wire on the solonoid goes to teh ecu and which to the ground cause i dont wanna mess it up?
Re: where on the p28 ECU do i run the wires for VTec solenoid and oil pressure? (degooser)
ok.. i have a p28 and i need pin locations for the my iacv (jdm b16b) there are two wires on that clip.. is one ground and one A9 right?? please help.
Re: where on the p28 ECU do i run the wires for VTec solenoid and oil pressure? (JV)
No it is not. This is the correct diagram...
Re: where on the p28 ECU do i run the wires for VTec solenoid and oil pressure? (purek9hybrid)
I've got a 95 civic with a D15b7, swapping in a D16Z6. Got the P28 ECU. Is this green connecter the VTEC oil pressure sensor? Also, where is the wire for the Knock sensor? Tell me where to look and I'll try to take another pic.
Re: where on the p28 ECU do i run the wires for VTec solenoid and oil pressure? (phresh_5)
Yes that is the Vtec pressure switch connector. P28 doesn't look for knock...
DJ_SaNdOz
21
01-19-2005 07:49 AM
