problem with tacho and speedo (del sol)
Old Feb 16, 2010 | 12:56 PM
vaptuning's Avatar
Icon6 problem with tacho and speedo (del sol)
Hello! I am a new user. I am from Latvia. This is the small country in Europe, cause my english language is with mistakes.
I have Honda Del Sol 92.year. D16z6 engine code. I have a problem with speedometer and tachometer. They often don't work both, or one of them. For example, when I turn on engine, they don't work, but after 5 minutes they work(or one of them). Other gauges work correctly. What the problem can be? Thanks
Old Feb 16, 2010 | 02:03 PM
gen2tegboi's Avatar
Default Re: problem with tacho and speedo (del sol)
I have a similar issue, mine is with the tach. It often works, but sometimes it doesn't. I bought a VSS and never installed it, I guess I learned to live with it. Now since you mentioned your speedo has the same problem, then I would try checking speedo cable connection and the vss.
Good luck, let us know if you find a solution.
Old Feb 16, 2010 | 06:11 PM
z6htch's Avatar
Check your ICM located in your dizzy. When your tach doesn't work, or jumps it usually means that your ICM goes bad. B/c it is connected to the tach and sends a signal to it.
Or could possibly be a wiring issue since the speedo isn't working also, I'm not 100% but hope this helps.
Old Feb 18, 2010 | 08:00 PM
smileydub's Avatar
i would check the connectors on the back of the cluster ive seen them come loose before especially if u go down real bumpy roads or the cluster has been messed with before and where not fully snapped back in to the socket
Old Feb 18, 2010 | 08:13 PM
CBR's Avatar
CBR
I've seen many reasons for this problem. Here's a couple simple things you can check: 1st: battery connections and grounds. I've seen bad grounds cause weird things, even the the car will still start. 2nd: Check charging system, I've seen failing alternators throw off speedo/tach on the dash. You'll need a multimeter, should read DC volts, around 13.6V (min) - 14.4V (ideal) with car running at idle.
Good luck
Bipolarcivic
12
Mar 27, 2016 03:34 PM
t-del28
Apr 23, 2011 06:40 AM
stupendo
Oct 15, 2006 05:27 AM
dr_liver_bones
16
Dec 7, 2005 07:38 PM
