B20 IN DC2--- WHICH DRIVER SIDE MOUNT???
OK, so droppin jdm b20 into my dc2... my hasport gsr motor mount has 3 holes in it (driver side mount)... my b20 mount bracket has only 2 bolts and they are not in the same pattern...so, i got a gsr motor bracket (goes on block-driver side) and replaced the b20 one with the gsr... but here is my problem/question...
the gsr mount hole pattern is different that the b20...the bottom bolt goes in fine, but the top two holes are seperated way more on the b20 block than the gsr bracket...so...am i using the wrong bracket??? or do i just mount the bracket using the bottom hole and one of the top ones?? im confused...
blufke
Jul 23, 2002 08:56 PM
