B16A TIMING BELT
Old Feb 15, 2010 | 06:06 PM
claymonthug's Avatar
Default B16A TIMING BELT
does anyone know what belt to use on jdm b16 obd0? or is it the same as b16a2 (00si)
Old Feb 15, 2010 | 06:15 PM
blasterman87's Avatar
Default Re: B16A TIMING BELT
actually the 00si had b16a3.. the a2 came from a del-sol vtec.. starting in 94, and the t-belt from any of those will work. its the water pump thats a oddball
Old Feb 15, 2010 | 06:17 PM
D16SiHatch's Avatar
you've got that backwards. a2 is in the em1, a3 in the sol. look it up
Old Feb 15, 2010 | 06:27 PM
yes, you are right. i remembered after i typed it... i just baught a cam seal today and they looked it us at the b16a2 it had me confused.
Old Feb 15, 2010 | 08:51 PM
so now what about the water pump? 94 del sol? part no. 19200-p30-003? because i was planning on doing that also
Old Feb 16, 2010 | 12:44 AM
hatchet_honda's Avatar
b18 ls motors have diff tooth water pumps. diff length belts. b16a all same
Old Feb 16, 2010 | 07:06 AM
so any B16 water pump is the same? but B18s are different then 16s?
Old Feb 16, 2010 | 08:43 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
A member named "Monty" compiled this list and it
was accurate for everything I replaced:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orifice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Old Feb 16, 2010 | 10:15 AM
What about the oil pan itself? will any B engines oil pan fit? or do i need to use one from a 94 del sol? or can i use a 91 tegs?
Old Feb 16, 2010 | 10:34 AM
schock3's Avatar
sticky that lol
DeDonDeRosa
Nov 11, 2008 05:16 PM
allnaturalb16
Feb 7, 2007 06:25 PM
CsRiX
Jan 8, 2005 12:28 PM
DOHCRX
Mar 7, 2003 04:59 AM
h46it
Sep 1, 2002 03:12 PM
