Need help im STumPed!!! PLZ
i have a b16a with a p28 ecu. im throwing my map sensor and tps code.
i am only able to rev up if i pull my plug off the map. just replaced tps after all this happend cause the plug looked faulty. and re-calibrated it.
tested them both for there voltage going in and return and they are perfect.
sill throwing code! tryed a different ecu. ran the same was gonna try to burn a new map but didnt know if that could be a cause. not a plugged air filter like someone else experience the same symtoms. checked all vacume hoses nothing there.
so i thing the last thing to check the my main wiring from my ecu through the firewall for a short somewhere.
anyone else think of anything or had this happen?
thanks for your time
You're supposed to flip the wires on the TPS right? Did you do that? I think if I remember correctly, the DPFI and MPFI read in reverse. So if you didn't do that, you may want to check that.
yah i did tryed a different ecu it didnt do anything different. tps is set correctly.
i will try to flip the tps wires around you mean just flip the plug right?
I think you need to de-pin it, and re-pin it. (plug should only plug in one way. So you just need to reverse the pins on the harness)
but my question is why would i have to do this now when it ran fine befor with out that. not tryin to be a idiot but im just not understanding.
