Clutch pressure Plz help
hey guys just got set up with a new flywheel and clutch on my 95 civic only one problem my clutch pedal is way too soft and it does not let me get into gear easily like it use to and now this morning i couldnt even get it to go into gear and when i try to reverse it grinds like crazy i checked my clutch fluid and idk if what i have to do is bleed the master cylinder and get new fluid ?? i hope not and hope this is an easy fix any help is appreciated
you just have to bleed the clutch line to get the pressure back in your pedal.. you can bleed it by pumping the clutch pedal 7-10 times then loosening the bleeder valve on the clutch master cylinder - make sure that you use a tube to run from the bleeder valve to a bottle filled with clutch fluid (dot 3 brake fluid is what you use) so that you dont get any more air in the line after bleeding - make sure to repeat this until you dont see any air bubbles come out of the bleeder valve and make sure to keep an eye on your clutch fluid reservoir so that the fluid doesnt run out and you end up suckin air back into the line
GL
GL
hondaless
Apr 2, 2009 08:58 AM
